Stripped Spark Plug
lukes6
Stripped Spark Plug
Post by lukes6 » Tue Nov 07, 2006 9:45 pm
Just after some advice i have got an EJ22 in a liberty that now has a stripped sparkplug hole.
It literally blew the plug out under its own power.
Just looking to find out if anyone has had any luck with using a helicoil to repair such a problem or whether i would be better off looking for another head to put on it.
Any tips would be great
Post by Subafury » Tue Nov 07, 2006 10:23 pm
i dont know if it'll help in this situation but there is some stuff u can buy to repair stripped threads. u like put the putty in the hole and the bolt thread and it like makes a new thread. dont know if it'll be resistant to high heats in the head tho and dont know how good it actually works. but yeh my 2c
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Nov 07, 2006 10:44 pm
Installing a helicoil is pretty easy and reliable way to fix the problem just make sure you get all the shavings out of the bore before starting the engine
The long road ahead
subelover
Post by subelover » Tue Nov 07, 2006 11:11 pm
yep def i have stuffed many a thread and helicoils have always been good...did a head on an ea82 and stripped 1 hole..when the car came back in for a retension and checkover all good no probs with it had a geeza...my 2c cheers BEN
Shauno
Post by Shauno » Wed Nov 08, 2006 9:31 am
Helicoils FTW!
Subaru MY01 WRX - Own:twisted:
daza
Post by daza » Wed Nov 08, 2006 12:20 pm
Shauno wrote:Helicoils FTW!
lol
Daza.
:D
lukes6
Post by lukes6 » Wed Nov 08, 2006 4:32 pm
Looks like a helicoil will be the first thing i try then.
The next question is can they be put in without taking the head off?
The plug seat is a long way in and how would you stop shaving going into the bore?
Cheers for you help guys
Post by El_Freddo » Wed Nov 08, 2006 4:37 pm
You'll have to vacuum out the shavings. Use a small hose that fits down the spark plug hole and fix it to the vacuum hose. Just make sure you do a good job of it.
If you could be bothered with the trauma of taking off the head and want the piece of mind that there's no shavings in the cylinder/chamber, go that way.
