Stripped Spark Plug
Stripped Spark Plug
Just after some advice i have got an EJ22 in a liberty that now has a stripped sparkplug hole.
It literally blew the plug out under its own power.
Just looking to find out if anyone has had any luck with using a helicoil to repair such a problem or whether i would be better off looking for another head to put on it.
Any tips would be great
i dont know if it'll help in this situation but there is some stuff u can buy to repair stripped threads. u like put the putty in the hole and the bolt thread and it like makes a new thread. dont know if it'll be resistant to high heats in the head tho and dont know how good it actually works. but yeh my 2c
- Suby Wan Kenobi
You'll have to vacuum out the shavings. Use a small hose that fits down the spark plug hole and fix it to the vacuum hose. Just make sure you do a good job of it.
If you could be bothered with the trauma of taking off the head and want the piece of mind that there's no shavings in the cylinder/chamber, go that way.
