ej22 to l series clutch question
tdg61
Post by tdg61 » Tue Jun 09, 2015 6:54 pm
Can someone tell me if I can use full ej22 clutch setup to mate l series 5 speed. If not why?
Post by TOONGA » Tue Jun 09, 2015 8:01 pm
Are you using an EJ22 motor And flywheel?
Do you have an adaptor plate?
Does your starter motor have the right throw out for an EJ22 flywheel?
tdg61
Post by tdg61 » Wed Jun 10, 2015 4:42 pm
Yes Toonga, I have ej22 with full clutch assembly, adaptor plate and l series 5 speed. I have looked for the answer to this question but can't find a definitive answer. I don't have a L
flywheel. I just want to know why this can or can't be done.
Post by TOONGA » Wed Jun 10, 2015 8:43 pm
From what Ive read in this document you will need to use the EA flywheel
If you made a hybrid EJ/EA dual range box you could use the EJ22 clutch kit.
tdg61
Post by tdg61 » Thu Jun 11, 2015 10:57 am
Good info there, but still doesn't explain why the ej flywheel and clutch assembly can't be used.
Post by AndrewT » Thu Jun 11, 2015 2:22 pm
Can't remember exactly why the EJ clutch and flywheel can't be used, but from memory it can't. Probably to do with the EA starter motor throwout. General rule of thumb is that you must match the clutch/pressureplate/flywheel setup to the gearbox. In this case all EA. Best to get a "heavy duty" EA pressureplate to handle the extra EJ power though.
EA flywheel needs the holes modified to suit the EJ engine.
Post by TOONGA » Fri Jun 12, 2015 9:27 pm
The main difference I can see which could stop you using an EJ flywheel and clutch kit with a EA gearbox is the flywheel itself.
EJ flywheel standard on left (rusty) dual mass on right (EJ22 is standard)
stolen from this thread showthread.php?t=17708&page=3
and the EA flywheel
stolen from this thread showthread.php?t=22607&page=4
The EA flywheel is stepped and the EJ flywheel is flat I'm not sure that the EJ flywheel would line up with the EA gearbox input shaft if you got the engine and gearbox together.
There would be only one way to find out, try putting it all together out of the car.
Post by El_Freddo » Fri Jun 12, 2015 10:58 pm
TOONGA wrote:The EA flywheel is stepped and the EJ flywheel is flat I'm not sure that the EJ flywheel would line up with the EA gearbox input shaft if you got the engine and gearbox together.
The input shaft will line up no worries, after all it needs to be centred for the engine to gearbox mating.
What the issue will be is the diameter size difference. I think you'll find that the EJ flywheel will foul the adaptor plate, then the starter motor won't line up as that's mounted to the gearbox on the L series casing.
I could be wrong though, can't say I've compared the EA and EJ flywheels closely.
Best way to keep the EJ clutch and fly wheel is to encase an L series 5 speed in the dual range EJ front cases from an AWD gearbox. Or just do the mods for the AWD box and go from there.
I've done the first one successfully twice now. Makes clutch replacement parts easy ;)
