ej22 to l series clutch question
Can someone tell me if I can use full ej22 clutch setup to mate l series 5 speed. If not why?
Can't remember exactly why the EJ clutch and flywheel can't be used, but from memory it can't. Probably to do with the EA starter motor throwout. General rule of thumb is that you must match the clutch/pressureplate/flywheel setup to the gearbox. In this case all EA. Best to get a "heavy duty" EA pressureplate to handle the extra EJ power though.
EA flywheel needs the holes modified to suit the EJ engine.
EZ30 L series - Monsterwagon
- TOONGA
The main difference I can see which could stop you using an EJ flywheel and clutch kit with a EA gearbox is the flywheel itself.
EJ flywheel standard on left (rusty) dual mass on right (EJ22 is standard)
![Image](http://i132.photobucket.com/albums/q4/WRC22B/Car%20Stuff/FlywheelFace.jpg)
stolen from this thread showthread.php?t=17708&page=3
and the EA flywheel
![Image](http://ausubaru.com.au/picture.php?albumid=187&pictureid=1596)
stolen from this thread showthread.php?t=22607&page=4
The EA flywheel is stepped and the EJ flywheel is flat I'm not sure that the EJ flywheel would line up with the EA gearbox input shaft if you got the engine and gearbox together.
There would be only one way to find out, try putting it all together out of the car.
and the EA flywheel
The input shaft will line up no worries, after all it needs to be centred for the engine to gearbox mating.TOONGA wrote:The EA flywheel is stepped and the EJ flywheel is flat I'm not sure that the EJ flywheel would line up with the EA gearbox input shaft if you got the engine and gearbox together.
What the issue will be is the diameter size difference. I think you'll find that the EJ flywheel will foul the adaptor plate, then the starter motor won't line up as that's mounted to the gearbox on the L series casing.
I could be wrong though, can't say I've compared the EA and EJ flywheels closely.
Best way to keep the EJ clutch and fly wheel is to encase an L series 5 speed in the dual range EJ front cases from an AWD gearbox. Or just do the mods for the AWD box and go from there.
I've done the first one successfully twice now. Makes clutch replacement parts easy
![Wink ;)](./images/smilies/icon_e_wink.gif)
