Rear Suspension Crossmember - 2WD v 4WD
damo666
Post by damo666 » Mon Jun 05, 2006 12:45 pm
I'm currently gathering some bits for the 2wd to 4wd conversion.
I seem to recall that the rear crossmember is actually the same between the two, and that it is just the arms that are different? Can anyone confirm this?
legacytt
Crossmember
Post by legacytt » Mon Jun 05, 2006 4:12 pm
G'day Damo,
Yes will be the same as you say, just swap over both trailing arms for the 4wd ones.
damo666
Post by damo666 » Mon Jun 05, 2006 7:23 pm
Cheers, that will make things a little simpler.
Thanks again.
wagonist
Post by wagonist » Fri Jun 30, 2006 7:22 pm
If you're talking about the rear suspension crossmember that extends across the car under the back seat, they are not the same. The 4wd one has the front diff mount welded onto it.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
Chris_Rogers
Post by Chris_Rogers » Sat Jul 01, 2006 7:22 am
x2.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
