Read up a fair bit on sealer stuff.
Getting my SPFI manifold reamed a few mm each side as heads closer together on reco engine.
Got a custom adapter for weber carb.
Got standard gasket for carbie to adapter and gasket paper adapter to manifold. Worried about-
1/ gaskets leaking under carbie. should I use permatex gasket sealer?
2/ I know you dont normally use anything with the two gaskets manifold to heads and torque up to around 15lbs. What do you do with those gaskets. ??
thanks in advance. Tony
Carb and manifold sealer
- Tweety
