All I needed was another four weeks before the Brumby gets put out to pasture , and this happens. 25,000km , 18 months earlier ( I left notes inside door) it got a rescued regulator, cost noted 'dog food" was the currency - for the guard dog
Scored a two door sedan door to pinch the regulator as they are same as Brumby. Turned out was not the greased up reg at all!
The forward track for the window runs a nylon sleeve on the window holding bracket. It had worn out, and jammed up the works.
part # 762243030
Lucky I bought the whole door for the window had a nice nylon sleeve to slip on. Lubed up the rear roller looking things, top one spins and slides about, the lower one is more fixed, riveted differently so not really designed to turn on its axle. Lubed it all up with Lanotec heavy duty, bolted next regulator in, slid glass in. Like bloody new, no rattles either (which is partly why I bought another ute at xmas
Even though this reg was stuck, the whole job was the easiest I have ever done with these windows and regulators. Musta finally worked them out !!
