MY window rattles, fixed like new car :)
Post by steptoe » Fri May 16, 2014 6:27 pm
My Brumby drivers window started to make awful scraping noises, got hard to wind so left it up, until a boom gate ticket dispenser tricked me.And there it stayed, jammed stuck.
All I needed was another four weeks before the Brumby gets put out to pasture , and this happens. 25,000km , 18 months earlier ( I left notes inside door) it got a rescued regulator, cost noted 'dog food" was the currency - for the guard dog :) - reads bad don't it ??
Scored a two door sedan door to pinch the regulator as they are same as Brumby. Turned out was not the greased up reg at all!
The forward track for the window runs a nylon sleeve on the window holding bracket. It had worn out, and jammed up the works.
part # 762243030
Lucky I bought the whole door for the window had a nice nylon sleeve to slip on. Lubed up the rear roller looking things, top one spins and slides about, the lower one is more fixed, riveted differently so not really designed to turn on its axle. Lubed it all up with Lanotec heavy duty, bolted next regulator in, slid glass in. Like bloody new, no rattles either (which is partly why I bought another ute at xmas :) )
Even though this reg was stuck, the whole job was the easiest I have ever done with these windows and regulators. Musta finally worked them out !!
Post by El_Freddo » Tue May 20, 2014 11:07 pm
It certainly pays to pull the door card off to sort out any inner door issues - but getting that door card off isn't the easiest, especially if you've not got a tool to remove the window winder handle!
One thing I hate is realigning the window if you've had the runners out or disconnected.
Why is this brumby being put out to pasture?
Post by steptoe » Wed May 21, 2014 7:50 am
Rattly window :) , rusted out tailgate at the hinge etc, no tarp, must have a million or more kms on it so generally just time to put the other one on once it gets sorted. I almost stole the new one :p
tambox
Post by tambox » Sun May 25, 2014 7:04 pm
Yep, much easier with the Jesus clip remover.
L serious, still.
Post by El_Freddo » Sun May 25, 2014 7:45 pm
steptoe wrote:Rattly window :) , rusted out tailgate at the hinge etc, no tarp, must have a million or more kms on it so generally just time to put the other one on once it gets sorted. I almost stole the new one :p
Going to make a trailer out of it?? I would :twisted:
Post by steptoe » Mon May 26, 2014 8:13 am
Trailer - no. Maybe a letterbox so it can be legally parked on the nature strip :)
