L Series, central locking, wanna do jaycar remote !
Post by steptoe » Sun May 21, 2006 11:44 am
Thinking of cheap and cheerful stuff to do to my L with factory central locking and would like to hook up a jaycar or similar remote
surely it is possible
anyone done this ?
thanks,
Oversteer
Post by Oversteer » Sun May 21, 2006 1:36 pm
You`ll need relays and a solenoid in the drivers door....as I believe it doesn`t have a solenoid factory only a swicth drivers door ;)
So its basically a central locking install...with only one solenoid in drivers.
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
Chris_Rogers
Post by Chris_Rogers » Sun May 21, 2006 2:32 pm
correct. if you use the jaycar remote item and grab an actuator for te drivers door then you are set.
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
SCOOBIDOO
Re: L Series, central locking, wanna do jaycar remote !
Post by SCOOBIDOO » Sun May 21, 2006 5:14 pm
jono wrote:Thinking of cheap and cheerful stuff to do to my L with factory central locking and would like to hook up a jaycar or similar remote
anyone done this ?
thanks,
i install these kits often..get the jaycar kit ,and inside you will have 3 slave lockers and 1 master locker for the drivers door..which operates the others when moved by the key or handle..you can even get the badass kit and have the remote button too! this is the kit i install...lockers with the button is the go!!! 1hr -2hrs and your good to go....cheers
Chris_Rogers
Post by Chris_Rogers » Sun May 21, 2006 5:42 pm
actually I can do one that will give you a boot pop as well. $130 if you are interested
unit is here:
http://www.mongoose.com.au/accessories/ ... id=MCL2000
Audio Express
Post by steptoe » Sun May 21, 2006 6:14 pm
OK. some of the thinking has been done for me. thanks
