L Series, central locking, wanna do jaycar remote !
Thinking of cheap and cheerful stuff to do to my L with factory central locking and would like to hook up a jaycar or similar remote
surely it is possible
anyone done this ?
thanks,
anyone done this ?
thanks,
You`ll need relays and a solenoid in the drivers door....as I believe it doesn`t have a solenoid factory only a swicth drivers door
So its basically a central locking install...with only one solenoid in drivers.
OS
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
- Chris_Rogers
- SCOOBIDOO
Re: L Series, central locking, wanna do jaycar remote !
i install these kits often..get the jaycar kit ,and inside you will have 3 slave lockers and 1 master locker for the drivers door..which operates the others when moved by the key or handle..you can even get the badass kit and have the remote button too! this is the kit i install...lockers with the button is the go!!! 1hr -2hrs and your good to go....cheersjono wrote:Thinking of cheap and cheerful stuff to do to my L with factory central locking and would like to hook up a jaycar or similar remote
anyone done this ?
thanks,
- Chris_Rogers
actually I can do one that will give you a boot pop as well. $130 if you are interested
unit is here:
http://www.mongoose.com.au/accessories/ ... id=MCL2000
unit is here:
