There has to be a comp ratio difference between the two engines anyone know the ratios and whether it is in the head or the piston to get the change ? thanks
my thoughts are if in the piston and I wanna raise compression with lpg to reduce turbo lag use either normal pistons or normal block and retain heads - in the future maybe !!
EA82T v EA82 comp ratios diff in head or piston
- Suby Wan Kenobi
