EA82T v EA82 comp ratios diff in head or piston
Post by steptoe » Wed May 17, 2006 2:19 pm
There has to be a comp ratio difference between the two engines anyone know the ratios and whether it is in the head or the piston to get the change ? thanks
my thoughts are if in the piston and I wanna raise compression with lpg to reduce turbo lag use either normal pistons or normal block and retain heads - in the future maybe !!
Suby Wan Kenobi
Post by Suby Wan Kenobi » Wed May 17, 2006 3:31 pm
The reduction is in the piston
The long road ahead
Ben
Post by Ben » Wed May 17, 2006 7:41 pm
Suby Wan Kenobi wrote:The reduction is in the piston
Just for another confirmation it is in the pistons, theres a hollowed out section. Comp ratio of the turbs is 7.7:1
Please watch before posting!
Post by steptoe » Wed May 17, 2006 11:19 pm
and a compression test reading would be ...? on turbo motor
