Brumby Uni joint part number
Post by El_Freddo » Fri Feb 15, 2013 11:11 pm
G'day,
I'm after the part number for the brumby's uni joint in the prop/tail shaft.
I've got one that's on the way out on Sunnie the Brumby and I figure I might as well swap both out at the same time...
Post by El_Freddo » Fri Feb 15, 2013 11:32 pm
Just managed to find this unit, but not 100% confident on the two part numbers provided.
Post by RSR 555 » Sat Feb 16, 2013 2:24 am
RUJ1781 is the correct number for the aftermarket version
Post by steptoe » Sat Feb 16, 2013 6:53 am
sounds awfully familiar - that R generally means Paul is steering you towards repco - 1781 likely to work elsewhere stores
Post by RSR 555 » Sat Feb 16, 2013 11:14 am
The R has noting to do with Repco.
RUJ1781 is a Hardy Spicer number
Post by El_Freddo » Sat Feb 16, 2013 9:25 pm
steptoe wrote:sounds awfully familiar - that R generally means Paul is steering you towards repco - 1781 likely to work elsewhere stores
Nope - the R determines where the retainer ring is - on the yoke or in the flange. From memory the brumby's is on the yoke (I should know this, I just had the tail shaft in my hand when I was in the shed!)
RSR 555 wrote:RUJ1781 is the correct number for the aftermarket version
Sweet. Thanks Paul!
Post by steptoe » Sat Feb 16, 2013 9:32 pm
consider my head pulled in - been in repco too recently, or maybe repco owns HS or they succumbed to repco part numbering ?
