L series alarm system and fitment
Can anyone recommend an alarm system to go into an L series.
Also, when installing an alarm, I would imagine breaking into the circuits for the electric fuel pump and the run on solenoid on the carby would te the go.
I think these may be off the same circuit though so is there a better place to apply an alarm
- Bantum
Options ...
As there are several types available - ( I've used python / DAE ) it's best to do a search for them on-line & hopefully it will help to sort out your best option.
Budget wise, you'd be starting with cheaper kits about the $50 mark - then ranging up to top of the line stuff ( with satelite tracking etc ) ... $1,000 +
It mostly depends on whether you are planing to do it yourself, or have someone install it for you ...
Doing it yourself is obviously cheaper, but if you don't know what you doing it can cause headache's later on ...
So set youself a budget and determine your best option, someone on here 'may be' able to help with the install - Check here first if you chose that route ...
Let us know how it goes ...
- littlewhiteute
As a 3 point immobiliser, you are better off interrupting the ignition primary circuit, the starter circuit and fuel pump as the 3rd option.Cliff R wrote:Can anyone recommend an alarm system to go into an L series.
The first 2 will give no crank AND no start.
Gary
Gary
