Brumby Fluids
- Brumby Kid
Brumby Fluids
Hey guys, just wondering how many litres the brumbys hold in the following...
Engine Oil
Gearbox
Diff
Coolant
Cheers Cam
Engine Oil
Gearbox
Diff
Coolant
Cheers Cam
- thunder039
- Silverbullet
Engine oil and coolant can be filled with a 5L bottle each, just don't pour the whole lot in, pour about half/3 quarters then check dipstick. For coolant park the car or jack it up so the front is highest, turn the heater dial to hot and fill it up. I usually then start the car up and watch as the coolant disappears into the air voids and keep topping up, take for a drive etc. But yours is a fresh rebuild so dunno how you'd go there. I've never had any troubles with trapped air bubbles with this method.
- Brumby Kid
So they take a whole 5 liters each in the end or a bit under?
What about the rear diff?
Cheers Cam
Cheers Cam
- Silverbullet
- TOONGA
Here you go Cam
CAPACITY AND GRADE
Engine:
Lubricant SF 20W/50
Sump capacity -
1979-1981 1600 cc models 3.5 litres
1979-1987 1800 cc models 4.0 litres
Cooling system capacity:
1979-1981 1600 cc models 5.3litres
1979-1987 1800 cc models 5.51itres
Manual transaxle two wheel drive models:
Lubricant SAE 80W-90
Capacity-
1979-1984 models 2.7 litres
1985-1987 Sedan and
Station Wagon models 2.61itres
Manual transaxle four wheel drive models:
Capacity -
1979-1984 and Utility models 3.0 litres
1985-1987 Sedan and
Station Wagon models 3.31itres
Automatic transaxle two wheel drive models,
transmission:
Lubricant. . . . . . . . . . . . . . . . . . . . . . .. Dexron II
Capacity 1983-1984 models -
Dry refill. . . . . . . . . . . . . . . . . . . . .. 5.6-6.0 litres
Capacity 1985-1987 models -
Dry refill. . . . . . . . . . . . . . . . . . . . .. 6.0-6.4 litres
Automatic transaxle four wheel drive models,
transmission:
Lubricant Dexron II
Capacity 1983-1984 models-
Dry refill. . . . . . . . . . . . . . . . . . . . .. 6.8-7.2 litres
Automatic transaxle, differential:
Capacity. . . . . . . . . . . . . . . . . . . . .. 1.1-1.31itres
Rear axle four wheel drive models:
Capacity 0.8 litres
Steering gear:
Lubricant -
Manual steering. . . . . . .. Subaru steering grease
Power steering. . . . . . . . . . . . . . . . . . .. Dexron II
Brake fluid type Dot 3 or 4
Fuel tank capacity:
1979-1982 Sedan. . . . . . . . . . . . . . . . .. 50 litres
1979-1982 Station Wagon
and Utility. . . . . . . . . . . . . . . . . . . . . . .. 45 litres
1983-1984 Sedan and Coupe " 601itres
1983-1984 Station Wagon
and Utility. . . . . . . . . . . . . . . . . . . . . . .. 55 litres
1985-1987 Sedan and
Station Wagon. . . . . . . . . . . . . . . . . . . .. 60 litres
1985-1987 Utility 551itres
from the gregorys here
Toonga
CAPACITY AND GRADE
Engine:
Lubricant SF 20W/50
Sump capacity -
Capacity-
1985-1987 Sedan and
Capacity -
1985-1987 Sedan and
transmission:
transmission:
Lubricant Dexron II
Capacity 0.8 litres
Steering gear:
Lubricant -
Fuel tank capacity:
1985-1987 Sedan and
Toonga
- Brumby Kid
Thanks guys
