Brumby Fluids
Brumby Kid
Brumby Fluids
Post by Brumby Kid » Wed Sep 26, 2012 6:47 pm
Hey guys, just wondering how many litres the brumbys hold in the following...
Engine Oil
Gearbox
Diff
Coolant
Cheers Cam
Dads Car: 02 Impreza WRX STi
thunder039
Post by thunder039 » Wed Sep 26, 2012 7:09 pm
3.0ltrs for the gearbox
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by Silverbullet » Wed Sep 26, 2012 7:21 pm
Engine oil and coolant can be filled with a 5L bottle each, just don't pour the whole lot in, pour about half/3 quarters then check dipstick. For coolant park the car or jack it up so the front is highest, turn the heater dial to hot and fill it up. I usually then start the car up and watch as the coolant disappears into the air voids and keep topping up, take for a drive etc. But yours is a fresh rebuild so dunno how you'd go there. I've never had any troubles with trapped air bubbles with this method.
Brumby Kid
Post by Brumby Kid » Sat Sep 29, 2012 6:51 pm
So they take a whole 5 liters each in the end or a bit under?
What about the rear diff?
Cheers Cam
Post by Silverbullet » Sat Sep 29, 2012 7:48 pm
A bit under usually, keep the rest in the car just in case :)
Post by TOONGA » Sat Sep 29, 2012 8:19 pm
Here you go Cam
CAPACITY AND GRADE
Engine:
Lubricant SF 20W/50
Sump capacity -
1979-1981 1600 cc models 3.5 litres
1979-1987 1800 cc models 4.0 litres
Cooling system capacity:
1979-1981 1600 cc models 5.3litres
1979-1987 1800 cc models 5.51itres
Manual transaxle two wheel drive models:
Lubricant SAE 80W-90
Capacity-
1979-1984 models 2.7 litres
1985-1987 Sedan and
Station Wagon models 2.61itres
Manual transaxle four wheel drive models:
Capacity -
1979-1984 and Utility models 3.0 litres
1985-1987 Sedan and
Station Wagon models 3.31itres
Automatic transaxle two wheel drive models,
transmission:
Lubricant. . . . . . . . . . . . . . . . . . . . . . .. Dexron II
Capacity 1983-1984 models -
Dry refill. . . . . . . . . . . . . . . . . . . . .. 5.6-6.0 litres
Capacity 1985-1987 models -
Dry refill. . . . . . . . . . . . . . . . . . . . .. 6.0-6.4 litres
Automatic transaxle four wheel drive models,
transmission:
Lubricant Dexron II
Capacity 1983-1984 models-
Dry refill. . . . . . . . . . . . . . . . . . . . .. 6.8-7.2 litres
Automatic transaxle, differential:
Capacity. . . . . . . . . . . . . . . . . . . . .. 1.1-1.31itres
Rear axle four wheel drive models:
Capacity 0.8 litres
Steering gear:
Lubricant -
Manual steering. . . . . . .. Subaru steering grease
Power steering. . . . . . . . . . . . . . . . . . .. Dexron II
Brake fluid type Dot 3 or 4
Fuel tank capacity:
1979-1982 Sedan. . . . . . . . . . . . . . . . .. 50 litres
1979-1982 Station Wagon
and Utility. . . . . . . . . . . . . . . . . . . . . . .. 45 litres
1983-1984 Sedan and Coupe " 601itres
1983-1984 Station Wagon
and Utility. . . . . . . . . . . . . . . . . . . . . . .. 55 litres
1985-1987 Sedan and
Station Wagon. . . . . . . . . . . . . . . . . . . .. 60 litres
1985-1987 Utility 551itres
from the gregorys here
Toonga
Brumby Kid
Post by Brumby Kid » Sat Sep 29, 2012 8:30 pm
Thanks guys
Return to “Trouble Shooting”
