Can any one tell me if you can test the module in an ea81 electronic distributor? And how?
Jeff
EA81 dizzy question
I don't know how to test it, but I know that the symptoms of a bad one are, it runs fine for a few minutes then stops dead. Of course every time you check for spark it has spark and so you start to blame other things. (plugs, leads, fuelpump/lines, that funny little box above the steering column ect) I found that the modules turn up on ebay from america at about half the price that auto electricians charge.
There was a method a bit like ' lick fingers and touch across the two contacts that wires go to and you might see a spark at a grounded plug end' but needs better explain.
these modules also found in things like some astras, honda civics, barinas and other things list of I had cannot find at the moment.
Zzzz
Zzzz
