Brumby engine replacement.
drkevorkian
Post by drkevorkian » Tue Apr 18, 2006 9:54 pm
The situation is... rolled my '91 brumby and have found an '85 model with a stuffed engine. I want to put my engine in the '85.
Is there going to be any major differences between the engine setup/mounting between these year models? Im hoping for a simple swap over.
Easy?
BaronVonChickenPants
Post by BaronVonChickenPants » Tue Apr 18, 2006 10:02 pm
It's likely there'll be different emissions crap, possibly different wiring as well, but all in all should be an easy swap.
Jordan
Post by AndrewT » Tue Apr 18, 2006 10:02 pm
I think there will be some slight wiring differences but I beleive the actual mounting will be a straight unbolt/bolt situation.
Overall should be easy, nothing a couple of questions and answers on Ausubaru won't solve when you're in the thick of it.
Post by steptoe » Tue Apr 18, 2006 10:29 pm
I believe it takes a trained eye to pick the differences between the two years other than headlights and oil dip stick, front brake callipers and clutch size
go for it
drkevorkian
Post by drkevorkian » Wed Apr 19, 2006 7:17 am
yeehaa!. off i go to pick up my wreck!
Thanks for the help.
