Vacuum from where??
kj0
Vacuum from where??
Post by kj0 » Wed Jun 30, 2010 10:42 pm
Hey Guys.
I have a couple of gauge I'm about to put in. I am however wondering Where to run the T-Piece off for my Vacuum gauge. Some Run it off the Brake booster line, or the intake - Fuel pressure regulator.
Any recommendation on a good place to put it? Would it be a good idea to follow through the same lines a boost gauge runs off as it is somewhat the same detail (ok, that's a very vague description and comparission of boost and Vacuum gauges.)
Post by El_Freddo » Wed Jun 30, 2010 10:58 pm
What ever you do I'd be trying to plumb it in as close to the manifold as I could... As to which line you tap into I don't think it really matters, just so long as it seals properly so there's no vacuum leak.
Post by Gannon » Wed Jun 30, 2010 11:19 pm
Easiest way is to get a 3mm T piece and put it in line with the vac line that feeds the HVAC system (Heating Ventilation Air Conditioning) Its the black hose that goes from the manifold to the little white canister mounted behind the drivers side strut tower.
kj0
Post by kj0 » Thu Jul 01, 2010 8:06 am
Awesome. I was looking at the two hose that go straight back into the AirFilter box. Front side, bottom corners.
So you reckon after the TB?
littlewhiteute
Post by littlewhiteute » Thu Jul 01, 2010 12:33 pm
kj0 wrote:Awesome. I was looking at the two hose that go straight back into the AirFilter box. Front side, bottom corners.
Of course after the throttle body, the gauge is for manifold vacuum.
Gary ;)
subarooster
Post by subarooster » Fri Jul 02, 2010 10:58 pm
Yeah its better to run it off something like the "Heating Ventilation Air Conditioning" so that if your T piece comes adrift at any time, you only lose your venting direction instead of sacrificing braking or anything important.
01' Liberty B4.
Post by El_Freddo » Sat Jul 03, 2010 12:31 am
You wouldn't actually lose your braking, just the effectiveness of your leg pressure - you'd need to use a lot more to get your vehicle to slow down, like you're trying your hardest to push a brick through the floor...
That said, you don't want it to happen!
kj0
Post by kj0 » Wed Jul 07, 2010 11:03 pm
littlewhiteute wrote:Of course after the throttle body, the gauge is for manifold vacuum.
Some Reviews were saying before was fine.
Post by Gannon » Thu Jul 08, 2010 6:46 am
You mean before the throttle body?
If you put it before the throttle body, the gauge will never move (unless your air filter is completely blocked)
What engine have you got?
EA82? EJ22?
kj0
Post by kj0 » Fri Jul 09, 2010 12:18 am
EJ20.
Yeah, Bizarre, But some reviews said Before. Which would be in the Air Box.
BUt. Can you pin point the best one?
Post by Gannon » Fri Jul 09, 2010 6:41 am
Any vacuum source on the manifold will do.
There is a hose that connects to the fuel pressure regulator, you could T this for your vacuum source or you could remove the little threaded plug and put a barbed nipple in there.
kj0
Post by kj0 » Fri Jul 09, 2010 12:20 pm
Hmm.. There's a few option I found and Wonder about. The Manifold and line are looking a little harder to get at then I've experiences on Alloytechs and Nissan Engines.
Here are a couple I've found.
The Fuel Regulator.
http://img697.imageshack.us/i/option1l.jpg/
Under the TB on the right under the valve
http://img34.imageshack.us/i/optiontwo.jpg/
On top of the TB
http://img805.imageshack.us/i/option3.jpg/
Those are the ones I found.
Couldn't find the one you were talking about though.
Post by Gannon » Fri Jul 09, 2010 3:27 pm
Option 1 is not the fuel pressure regulator
Option 2 is a coolant hose
Option 3 is ported vacuum so you will only see vacuum at partial throttle.
I'll have my car this afternoon after i drop off the work truck and i'll take a photo for you
Post by Gannon » Fri Jul 09, 2010 5:06 pm
Your best bet is to buy a T piece and put it in line with the fuel pressure regulator vacuum hose
It is the small pipe below the brake booster line.
kj0
Post by kj0 » Fri Jul 09, 2010 5:08 pm
OH man does it suck to have people telling you the wrong information. That was apparently the fuel regulator, but thats good.
That would be really handy thanks.
