ej22 ecu question
mrmattyking
ej22 ecu question
Post by mrmattyking » Fri Jun 04, 2010 10:17 pm
Hi, I'm converting l series to ej22, the donor car is an auto, bolting it to the ea 5 speed gearbox, Does anyone know if the ej22 auto ecu will be ok or will i need to get one from a manual, or as i have read on some websites that it's possible to remove a chip or 2 out of the auto ecu to convert it to a manual ecu?? any info would be much appreciated. Cheers.
Post by TOONGA » Fri Jun 04, 2010 10:28 pm
no need to convert the ecu just remove the Auto trans wire from the harness
Im sure someone will confirm this
Post by Gannon » Fri Jun 04, 2010 11:07 pm
Yeah it will be fine, you might just have to bypass the inhibitor switch.
Post by El_Freddo » Sat Jun 05, 2010 12:01 am
TOONGA wrote:no need to convert the ecu just remove the Auto trans wire from the harness
Agreed. Dunno about the inhibitor switch though, I thought it was just this wire that you didn't worry about (cut and tape to isolate it) and you're done with the auto stuff.
Post by guyph_01 » Sat Jun 05, 2010 10:09 am
I've got a auto ECU in my conversion and its all fine:)
mrmattyking
Post by mrmattyking » Sat Jun 05, 2010 10:38 am
ok sounds good,
cheers for that guys.
