ej22 problems
Josho
ej22 problems
Post by Josho » Mon Apr 26, 2010 2:33 pm
hey guys having a few problems with my motor its a 94 ej22 under full throttle just misses i thought maybe could have been plugs leads so changed all this and also air filter and oil/oil filter moter accelarates hard and fine if i keep 3/4 throttle car then wants to stall at low idel also any help would be great thanks
Josh.
Post by AlpineRaven » Mon Apr 26, 2010 8:46 pm
can you explain a bit more, is it automatic or manual? is it a Liberty?
Post by RSR 555 » Tue Apr 27, 2010 9:09 am
I had this just the other day.. Check to see if all the breather pipes to the intake are connected.. especially look at the one that goes to the Air Bypass Valve which is just to the divers side of the throttle body.
Post by AlpineRaven » Tue Apr 27, 2010 9:33 am
RSR 555 wrote:I had this just the other day.. Check to see if all the breather pipes to the intake are connected.. especially look at the one that goes to the Air Bypass Valve which is just to the divers side of the throttle body.
It would be causing stalling problems at idle..
Post by RSR 555 » Tue Apr 27, 2010 9:35 am
AlpineRaven wrote:It would be causing stalling problems at idle..
Yep.. which is the symtoms he is getting
Josho
Post by Josho » Mon May 03, 2010 2:27 pm
thanks guys been working in brissy last week so filled up a full tank of ultimate and gave it a good run through seems to be running fine for now maybe dirty injectors not sure
its a manual 89 l series with a ej22 AP
