ej22 problems
ej22 problems
hey guys having a few problems with my motor its a 94 ej22 under full throttle just misses i thought maybe could have been plugs leads so changed all this and also air filter and oil/oil filter moter accelarates hard and fine if i keep 3/4 throttle car then wants to stall at low idel also any help would be great thanks
Josh.
Josh.
can you explain a bit more, is it automatic or manual? is it a Liberty?
I had this just the other day.. Check to see if all the breather pipes to the intake are connected.. especially look at the one that goes to the Air Bypass Valve which is just to the divers side of the throttle body.
It would be causing stalling problems at idle..RSR 555 wrote:I had this just the other day.. Check to see if all the breather pipes to the intake are connected.. especially look at the one that goes to the Air Bypass Valve which is just to the divers side of the throttle body.
Yep.. which is the symtoms he is gettingAlpineRaven wrote:It would be causing stalling problems at idle..
