forrie ?????s
According to the FSM, 1.447:1 with a 4.111:1 final drive
Something else interesting i found in the Gen3 Liberty/Outback FSM
2.0L Dual Range models got a 1.447:1 low range
2.5L Dual Range models got a 1.196:1 low range
I didnt know this.
It should also be noted that the 2.0L has a 3.9:1 final drive and the 2.5L has a 4.111:1 (3.7:1 outside Australia) final drive
I didnt know this.
correct..shuffbag wrote:does this mean a better low range in 2.0L's? im not the best at figuring witch way ratio's read
The lower the better ie. 1.59:1 in L Series etc..
1.19:1 is almost useless..
Plain English Dibs you should be ok if your not doing a lot of hard tracks
If there is any good runs coming up from the club:rolleyes:that suit the low range i'll let you know
You can see for your self and make up your own mind if you want to put the l-series low in it
You could always give (grewi forum name) bill (in the club) a ring he lives near you next door nearly he loves going off road there's plenty of tracks up at Glasshouse send him a pm or give him a ring he is in the members list.
Jan
Jan
yes with mods.dibs wrote:corect me if im wrong an lseries low rang fits a forrie box???? . if so i need a forrie box and a lseries box and time and patience to do it .prob with lots of ????????.
dibs
Me either. VERY interesting...Suparoo wrote:According to the FSM, 1.447:1 with a 4.111:1 final drive
I didnt know this.
Mmm yes truth is out...El_Freddo wrote:Me either. VERY interesting...
But......Suparoo wrote:According to the FSM, 1.447:1 with a 4.111:1 final drive
I didnt know this.
Look at the 5th gear ratio!
