gen2 manual to auto conversion
wrxer
Post by wrxer » Fri Nov 06, 2009 11:06 pm
considering changing the outback to auto. not real worried about the mechanical changes such as box, tailshaft, rear diff, console and pedal box. but would appreciate any info for wiring and such, are all the plugs there, is it plug and play or a bit more serious?
thanks
Outback bloke
Post by Outback bloke » Sat Nov 07, 2009 4:07 am
It involves a complete harness change. Put it this way, to fit an auto you need to remove your dash and all the wires behind it and swap it for a harness to suit your gearbox.
Post by Gannon » Sat Nov 07, 2009 7:52 am
Its actually gonna be easier and cheaper to buy an auto outback
There are lots of sensors to integrate to make the auto work.
Post by TOONGA » Sat Nov 07, 2009 1:42 pm
yep the ecu needs to be changed (auto one is different to manual) there is a harness that goes to the auto box thats different there is an ecu for the box you need the auto dash and associated loom (just looking at the wreckers before) (sadly no MY ventilated discs and rotors :( )
Post by AlpineRaven » Sat Nov 07, 2009 3:49 pm
its a complicated task mate... it would be either ideal to have donor car to have before you start the project. I personally think its lot easier if you change whole car to automatic outback.
wrxer
Post by wrxer » Sun Nov 08, 2009 5:06 pm
thats what i didnt want to hear. maybe this is the push i need to get a gen 4.
thanks for the knowlege sharing
Post by AlpineRaven » Sun Nov 08, 2009 7:57 pm
wrxer wrote:thats what i didnt want to hear. maybe this is the push i need to get a gen 4.
Yeah I understand, its good to spill the beans here for opinions. Ive done it before from manual to automatic and man it was a hell of a job (took me a month to finish everything off backwards & forwards to wreckers for bit by bit..) and it wasn't "right" at the end and never will. Havent got that car anymore anyway.
wrxer
Post by wrxer » Mon Nov 09, 2009 11:36 am
so i should get a gt auto halfcut and put the lot in. are the loom plugs the same? ie. the door plugs and rear loom plugs
Post by AlpineRaven » Tue Nov 10, 2009 6:48 pm
wrxer wrote:so i should get a gt auto halfcut and put the lot in. are the loom plugs the same? ie. the door plugs and rear loom plugs
If its same year outback then it'll be easy.
In my experience between Series 1 & 2 Gen 2 Liberty (late 1994 Gen 2 & late 1996 Gen 2) I've noticed different colour codes of wiring. So thats a downside.
tex
Post by tex » Wed Nov 11, 2009 1:17 pm
Yeah even my Gen 1 GX's had different wiring harness but I had similar issues but to you but wanted to go auto gen 2 to man!
87 targa brumby (Neglected),
+ others.
