Rear struts sqeuaking
someguy
Post by someguy » Sun Nov 01, 2009 12:36 am
Hi All.
My L Series has recently developed a squeak coming from the rear springs/shocks.
They are only 8 months old so they are not in bad shape they just squeak while driving (my street is a little bumpy so its pretty annoying).
Anyone have any ideas what I could be and how I could fix it.
Thanks Alot.
chubby37
Post by chubby37 » Sun Nov 01, 2009 1:49 am
spray CRC or WD40 and let it soak then take her for a drive...mite need a couple of sprays...just sounds a little dry
someguy
Post by someguy » Sun Nov 01, 2009 9:40 am
chubby37 wrote:spray CRC or WD40 and let it soak then take her for a drive...mite need a couple of sprays...just sounds a little dry
Thanks will do.
someguy
Post by someguy » Sun Nov 01, 2009 12:29 pm
Well I applied RP7 all over the springs and struts and went for a drive and the squeaking is still there.
Maybe its not coming from them.
Anyone got any ideas what it could be?
Post by AndrewT » Sun Nov 01, 2009 12:38 pm
Bushes. If they weren't renewed when the new shocks went in maybe they need to be. Otherwise just some lube, however WD40 etc are petroleum based I think and might ruin the bushes. There is special stuff you can use, BlackBox Motorsports on here should have some advice.
someguy
Post by someguy » Sun Nov 01, 2009 1:22 pm
AndrewT wrote:Bushes. If they weren't renewed when the new shocks went in maybe they need to be. Otherwise just some lube, however WD40 etc are petroleum based I think and might ruin the bushes. There is special stuff you can use, BlackBox Motorsports on here should have some advice.
Yeah I might get the mechanics to check the bushes when I get the CV joint done next week.
The sqeaking only happens while im driving.
If I jump up and down on the car or shake it side to side when its stationary there is no squeaking.
Its only when driving.
chubby37
Post by chubby37 » Sun Nov 01, 2009 6:02 pm
lithium greese.............i think thats how they spell it
FROG
Post by FROG » Sun Nov 01, 2009 6:16 pm
Are you sure it's not the stabilizer bar bushes ? Mine were painfully squeaky when driving over bumps
Post by AlpineRaven » Sun Nov 01, 2009 8:47 pm
I did have a squeak in my rear on my wagon a few months ago, used lithium grease spray on all "moving" joints ie. sway bar etc and it went away straight away after i applied, it hasn't come back ever since.
