Brumby ea81 - Reco heads installed water in oil
justincase41
Post by justincase41 » Thu Oct 22, 2009 7:18 pm
Howdy,
Just finished installing a pair of reco heads on the ea81 donk. Heads had the full works by engine shop. Use loctite aviation hardening cement on inlet manifold gaskets, adjusted valve clearances. When I started her up, checked everything, topped up coolant, notice coolant dropping like crazy, engine running great. No leaks observed from anywhere. Checked the dip stick and it has the oil/water junge. Took the rocker covers back off and they were full of oil/water mix. Checked head torque(64nm), found one nut a little loose, adjusted valve clearances, removed inlet manifold and replaced the new gaskets with gasket goo. When I installed one of the gaskets, i accidentally grazed and bent it (Reinfoced with metal) and I suspected that it was going to cause drama's in the first place. Cleaned up everything, re-installed rocker covers and topped up coolant. Started her up and let her run for a while. Again, oil/water gudge on dip stick, no drop in coolant. Rocker covers off again, water/oil sludge in covers. Checked all PVC hoses, all gunged up. Cleaned everything again, checked head torque again all good. Cleaned eveything, re-installed everything and tighed all up. Changed oil as well. Took for approx 25km run. Runs great, checked coolant, no drop but oil/water gunge all over dip stick and hoses on rocker covers have oil/water gunge as well.
Whats doing on..................
I am suspecting that my gasket goo inlet manifold fix might be causing issues (Have ordered some new gaskets from Subaru). Should I have used a head gasket sealant? Anything else I should be looking at as I'm totally lost on this one.....
Current :
1992 Brumby (Future EJ20 Conversion)
2007 Toyota Prado 120
2012 Great Wall V200 (daily driver)
1997 Subaru Outback
1999 Toyota Surf (Beach Basher)
Past:
To Many to list!
Post by TOONGA » Thu Oct 22, 2009 7:46 pm
did the welch plugs in the heads get replaced ?
were the heads pressure tested?
did you clean the engine completely before you put it back together the second time?
did you change the oil filter?
all mistakes Ive made
justincase41
Post by justincase41 » Thu Oct 22, 2009 8:05 pm
Heads had the works including welsh plugs and pressure, crack tested.
Cleaned all surfaces with that gasket remover then wiped everything down really well. Going to replace inlet manifold gaskets with genuine suby ones when they arrive.
Oil filter................................................................ BUGGER!!!!!!!!!!!!!!!!!!
There is probally moisture and water in the filter and is being pumped around the motor!!! Didn't even cross my mind!
Current :
1997 Subaru Outback
Past:
To Many to list!
phillatdarwin
Post by phillatdarwin » Thu Oct 22, 2009 9:25 pm
I would say that the oil filter is where it is coming from.
Post by TOONGA » Thu Oct 22, 2009 10:29 pm
yep an oil filter full of soup does it every time :)
Ive had it happen
Post by steptoe » Fri Oct 23, 2009 8:07 am
u didn't say you changed oil and flter when heads went back on. I say if you didn't that could be your problem, someone forgot ot tell you? Also after a run, leave oil fill cap off and stick on your seat to remind you on start up. This will help water to steam off the oil so long as you have not achieved the ol pressure helps water and oil mix
justincase41
Post by justincase41 » Fri Oct 23, 2009 5:56 pm
Yea was a long week at work!!! And a simple thing like oil/oil filter change on head change over..............
When I got home from work, chanked inlet manifold gaskets, flushed engine with engine flush, new oil and oil filter and all problems sorted!!!
Current :
1997 Subaru Outback
Past:
To Many to list!
