i have got a car now. It is a 1990 touring wagon. 300,000 on the clock. I got it for $400.
the good bits... fairly straight body, only small dents on the bonnet. tyres are at about 85%. came with half a tank of fuel!
The bad bits... boot on Left CV is busted, the joint its self is still fine (for now).
Oil leak from an unknown location. I done a quick degrease and pressure clean today, but i was unable to pinpoint the leak.
Surface rust bottom of drivers door and windscreen. This should be no real problem, just a bit of rust kill should do the job( see photos).
The gear box is only High range
I only thought of taking photos after i had already started to pull things apart. Sorry they are so small. I havnt got photobucket worked out yet..
Tell us what you think. Any suggestions or what ever are welcome.
Cheers!
Mitch
