left power window switch
sooby
Post by sooby » Tue Sep 15, 2009 2:44 pm
the switch will go up but not down
Post by steptoe » Tue Sep 15, 2009 7:52 pm
turn the switch uside down? C'mon sooby tell us more, like the model, and if the condition is a problem to you. If this problem was mine, and it was in my old L wagon, I would try removing door trims off two non driver doors and try swapping switches to see if problem stays with window or goes with switch. Only just tossed my wagons switches last month.Does the master switch fix things or the same from it too. My master had the problem and just needed to use the door own button to get window up again.
openflame06
Post by openflame06 » Sun Oct 04, 2009 2:06 pm
A good place to start would be taking the switch out, check what wires are linked up and if there is any corrosion. See if power is going through with a multimeter.
red_rocket
Post by red_rocket » Sun Oct 04, 2009 8:26 pm
on my 88 L series wagon i can winde the passenger window down fine from the passenger switch but cannot winde it from the driver side main switch. Haven't looked at it to be honest but taking the trims off is a good start
L series project
http://www.ausubaru.com/forum/showthread.php?t=14491
Rolling in the 99 Rex though :D
Post by guyph_01 » Sun Oct 04, 2009 8:37 pm
mines the same as Red_rocket. the elec window works fine with the passenger control but when i use the main driver control switch i can only get the window to go down but not up. Its in a 89 touring wagon.
Matt
Post by Matt » Sun Oct 04, 2009 9:26 pm
The problem will more then likely be dirt contacts. You need to pull the trims off and pull the switch out. On the back of the switch there is two screws pull these out carefully screw into plastic. Also note that there is a few little pieces behind there so carefully part (usually easiest to undo screws, keep pressure on the switch to keep it together and turn it so the the screws face down and pull it apart slowly over a bench incase anything gets dropped :-P ) In the bottom of the switch is two pieces of copper with contacts on both ends of both pieces (note their postion) and another 4 on the switch that meet up with these. All 8 contacts need to be spotless clean. You can use a screw driver or some sand paper to clean them up. Don't worry about the balls and springs on the black switch thing they have no electrical use just mechanical. And put it all back together carefully making sure all the parts ar in the right way, etc. With practice you should be able to do the hole job in about half and hour.
Also all the switchs work very similiar and it will usually pay to do all of them at once because if one is dirty enough no to work the others won't be far behind it. If you do get stuck with the window down pull the bottom trim off and apply earth and 12volts to it. One way wil make it go up and switch the wires to come down. :-)
Post up here if you have any other dramas with it, i have heaps of knowledge on the power windows.
"Claudia"
red_rocket
Post by red_rocket » Mon Oct 05, 2009 1:20 am
hahaha, sounds like you have encountered this before, thanks heaps for all the info and i will give her a crack.
L series project
Matt
Post by Matt » Tue Oct 06, 2009 6:11 pm
No Drama's, i have owned my ute coming up to tens years and i am always around Subi so i know a few things......... But i am always learning new things...
"Claudia"
