Having a gearset machined up
hey guys im desperat now trying to get my scat transfer case going again, needs new high range gearset and finding a replacement is impossible
who in perth can machine up gear cogs? its gonna be expensive but i no longer have a choice on the matter
ANY help much appreciated
btw converting to another transfer case is out of the question atm,
cheers
dave
cheers
dave
- vincentvega
i tried a few without successs. if u have any reccomendations i would GREATLY appreciate it
dave
dave
- thatsgoodsquishy
Any help?
http://www.tradingpost.com.au/Automotiv ... tView=true
more
http://www.autosource.com.au/daihatsu-w ... -parts.php
http://www.yellowbook.com.au/Detail-Sta ... ECKERS.htm
more
Ben
Current: MY 07 Outback 3L
Previous: 02 B4 Manual
Previous: 95 Liberty Wagon 'Rallye'
Previous: 85 L series Touring Wagon, Auto to Manual conversion
that one in the trading post could be good...the others ive all seen..
thanks for the link...gonna call him in 2 minutes
dave
dave
what kind of gearset do you need it machined?
high range gears out of transfer case......its a very simple tc from the 70's
dave
dave
- FROG
was a place called gearcutters w.a. a few years ago that would do one off jobs in perth but i cant remember where dont know if he still operating but check the phone book
cheers Andy
cheers Andy
Dave , I use these people http://www.albinsgear.com.au/ quality & good heat treatment
Gear cutters Wa is a was of time & $
im thinking about albins.. the gearbox i currently have in the scat has been fully rebuilt with albins gears in it
dave
dave
check my signature..Thalass wrote:So would it be possible to get these guys to make a new transfer case gearset for an outback? To give it a better low range gearing.
Just curious - that seems to be one of the problems with the newer subarus.
Thalass, check out Alpine Raven's Low Range EJ gearbox write up. You should beable to do this with your outback without too much trouble if you really want a decent low range.
i was quoted $1200 for 2 very simple very basic cogs.
i decided not to get it done....lol.....i cant justify that much on what i was doing
but for a car like yours it may be worth it? i dont know
dave
dave
If you had access to an lathe then you're lucky....
not at all..i have access to a whole machining shop
need a slotting machine, grove turning machine and all sorts.
otherwise i would have made my own. gears require specialised machines
dave
dave
