Having a gearset machined up
Post by D3V1L » Tue Apr 28, 2009 12:28 am
hey guys im desperat now trying to get my scat transfer case going again, needs new high range gearset and finding a replacement is impossible
who in perth can machine up gear cogs? its gonna be expensive but i no longer have a choice on the matter
ANY help much appreciated
btw converting to another transfer case is out of the question atm,
cheers
dave
vincentvega
Post by vincentvega » Tue Apr 28, 2009 8:25 am
dihatsu Scat?
Have you tried some east coast wreckers? I helped a mate do one up years ago. There were plenty of spares available in brisbane
Post by D3V1L » Tue Apr 28, 2009 7:45 pm
i tried a few without successs. if u have any reccomendations i would GREATLY appreciate it
dave
thatsgoodsquishy
Post by thatsgoodsquishy » Tue Apr 28, 2009 8:10 pm
Ben
Current: MY 07 Outback 3L
Previous: 02 B4 Manual
Previous: 95 Liberty Wagon 'Rallye'
Previous: 85 L series Touring Wagon, Auto to Manual conversion
Post by D3V1L » Tue Apr 28, 2009 8:46 pm
that one in the trading post could be good...the others ive all seen..
thanks for the link...gonna call him in 2 minutes :D
dave
90brumby
Post by 90brumby » Tue Apr 28, 2009 9:44 pm
howd ya go dave theres a few places we use through work if ya need it but it will b rather pricey
let me no if ya want there address might b able to give ya a quote
tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by AlpineRaven » Tue Apr 28, 2009 10:09 pm
what kind of gearset do you need it machined?
Post by D3V1L » Tue Apr 28, 2009 10:48 pm
high range gears out of transfer case......its a very simple tc from the 70's
dave
FROG
Post by FROG » Wed Apr 29, 2009 12:58 pm
was a place called gearcutters w.a. a few years ago that would do one off jobs in perth but i cant remember where dont know if he still operating but check the phone book
cheers Andy
seagull
Post by seagull » Thu Apr 30, 2009 12:23 am
Dave , I use these people http://www.albinsgear.com.au/ quality & good heat treatment
Gear cutters Wa is a was of time & $
Post by D3V1L » Thu Apr 30, 2009 8:18 pm
im thinking about albins.. the gearbox i currently have in the scat has been fully rebuilt with albins gears in it
dave
seagull
Post by seagull » Fri May 01, 2009 12:54 am
yes they have the program
Thalass
Post by Thalass » Fri May 01, 2009 7:43 pm
So would it be possible to get these guys to make a new transfer case gearset for an outback? To give it a better low range gearing.
Just curious - that seems to be one of the problems with the newer subarus.
Post by AlpineRaven » Fri May 01, 2009 10:23 pm
Thalass wrote:So would it be possible to get these guys to make a new transfer case gearset for an outback? To give it a better low range gearing.
check my signature..
Post by El_Freddo » Fri May 01, 2009 10:31 pm
Thalass, check out Alpine Raven's Low Range EJ gearbox write up. You should beable to do this with your outback without too much trouble if you really want a decent low range.
seagull
Post by seagull » Sat May 02, 2009 1:04 am
Yes they can make any gear set you like , I had one done for a two wheel drive auto last year & it was easy
Thalass
Post by Thalass » Mon May 11, 2009 11:02 pm
I'm mostly just curious, as I'm not going to spend a huge amount on the outback now. But it is good to know. I may be in need of a custom gearbox or two at some stage.
I suppose it'd be pricey, though. :P
Post by D3V1L » Mon May 11, 2009 11:17 pm
i was quoted $1200 for 2 very simple very basic cogs.
i decided not to get it done....lol.....i cant justify that much on what i was doing
but for a car like yours it may be worth it? i dont know
dave
Post by AlpineRaven » Tue May 12, 2009 8:53 pm
If you had access to an lathe then you're lucky....
Post by D3V1L » Tue May 12, 2009 9:06 pm
not at all..i have access to a whole machining shop
need a slotting machine, grove turning machine and all sorts.
otherwise i would have made my own. gears require specialised machines
dave
Return to “Western Australia”
