ea82 lifters
ea82 lifters
hi i was wondering if any1 can give me sum advice on changing lifters in a ea82 thanx
Yep, leave them as the next set you put in will be the same...
Try a thinner oil, see how that goes first.
Otherwise you could remove the cams and swap out the lifters then put it all back together... I don't know if you'll need to remove the engine from the MY engine bay or not, you'll work that out on your own.
well i already put thinner oil in it and it just made it worse my brumby has a ea82 in it so there is no room to get the bolts out i want a ea81 to put in it so i dont have to **** around with all the shit but no1 seems so want to give them up and there is no where around me to buy one from a wreckers
