ea82 lifters
MOONEY
ea82 lifters
Post by MOONEY » Sun Aug 24, 2008 9:25 pm
hi i was wondering if any1 can give me sum advice on changing lifters in a ea82 thanx
theclick
Post by theclick » Sun Aug 24, 2008 9:38 pm
Don't mention the 'L' word
*Adjusts his hearing aid
Post by El_Freddo » Sun Aug 24, 2008 9:50 pm
Yep, leave them as the next set you put in will be the same...
Try a thinner oil, see how that goes first.
Otherwise you could remove the cams and swap out the lifters then put it all back together... I don't know if you'll need to remove the engine from the MY engine bay or not, you'll work that out on your own.
Post by steptoe » Sun Aug 24, 2008 9:52 pm
whether to do it or how to go about it ?
I noticed exchange units mentioned at about $6 or $8 outright each on a US site. Seen em here for as much as 70 bucks each
if you asking advice, tell a bit more to get a better answer maybe ?
MOONEY
Post by MOONEY » Mon Aug 25, 2008 8:22 pm
well i already put thinner oil in it and it just made it worse my brumby has a ea82 in it so there is no room to get the bolts out i want a ea81 to put in it so i dont have to **** around with all the shit but no1 seems so want to give them up and there is no where around me to buy one from a wreckers
timmo
Post by timmo » Wed Aug 27, 2008 3:05 pm
have you tried replacing the oil pump seals? usually quietens them down unless they're really worn
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
MOONEY
Post by MOONEY » Wed Aug 27, 2008 5:29 pm
nah i might have to give that a try but at the moment i cant drive it because the noise is so loud that i can hear it from 50m away so im going to change lifters and then if that dont help might change the oil pump seal
