lib lx shafts the same as gx?
SUBIIE
Post by SUBIIE » Thu Aug 07, 2008 2:47 pm
hi team,
have a pair of gx shafts but have a friends front wheel drive lx lib that needs a new shaft.
Are they the same sized shafts, or can i swap the shafts over?
Outback bloke
Post by Outback bloke » Thu Aug 07, 2008 3:21 pm
You can swap them between the two cars.
Post by AlpineRaven » Thu Aug 07, 2008 5:20 pm
Yep they're both the same. Apparently FWD shafts are thicker & stronger than AWD ones.
Post by El_Freddo » Fri Aug 08, 2008 11:58 am
AlpineRaven wrote:Yep they're both the same. Apparently FWD shafts are thicker & stronger than AWD ones.
On the L they were the other way around - thin shafts on the 2wd and thick on the 4wd fronts only... Go figure!
It appears my L has been running 2wd front shafts since before I got it...
