fuel system for ej conversion
hi there guys, i've had a bit of a look around and a search without much luck. i have an l series wagon and an EJ22 to go into it. what do people do with the fuel system ? i've seen setups on other cars with an engine bay mounted surge tank, fed by the std pump. or do i somehow find a tank from a liberty or something ? or modify the tank to take an intank pump ? how have people done it ?
also keep in mind if its carby u need a good return line and most carbys have a nice big evap that you can utalise
Hunter S. Thompson
Hunter S. Thompson
ok, had a bit of a hunt around today on the interwebs and a local wrecker. the mpi tank sounds the go and the neatest. they unfortunately don't seem too thick on the ground. i had a look at venom's conversion and i reckon i could feed a swirl pot with the standard fuel pump. his looks to be mounted in the rear of the car. oh well, i'll keep looking and see what presents.
That's the other way to do it. If you do manage to get an MPFI tank, make sure you get another fuel line for the return, it wouldn't matter if you get a second carbie fuel line, it just has to be a large diametre.briney wrote:ok, had a bit of a hunt around today on the interwebs and a local wrecker. the mpi tank sounds the go and the neatest. they unfortunately don't seem too thick on the ground. i had a look at venom's conversion and i reckon i could feed a swirl pot with the standard fuel pump. his looks to be mounted in the rear of the car. oh well, i'll keep looking and see what presents.
Keep an eye out at wreckers, I didn't see any around this weekend. Also check out the wreckers page in the vic section, I've just "updated" for the joints I drop in on from time to time.
