Rims on my camper
SuBaRiNo
Rims on my camper
Post by SuBaRiNo » Tue Jun 17, 2008 11:00 pm
Im trying to work out what rims are on my camper trailer so i can try and locate a set of white offroad style rims for it.
They are 4 stud (not subaru). Ford or Holden... how do i tell?
Also would anyone know how hard this would be to change to Subaru stud pattern if i wanted to change it?
Dave
Point
Post by Point » Tue Jun 17, 2008 11:08 pm
ford/holden have 4 stud? most of those would be re-badged jap cars wouldn't they?
measure the PCD of the studs, and find some wheels to suit, or re-drill the hubs/buy hubs with the right stud pattern(if you can get them)
4x100 is fairly common late model FWD
4x114.3 is old Datsun/Toyota etc.
98 Forester GX
02 Forester XS Luxury
Post by AndrewT » Wed Jun 18, 2008 12:44 am
4 x 110 is the very rare early Mazda pattern found on old RX-7's etc
Yeah just measure the PCD and you will find out. I'd imagine to change stud patterns you would have to knock the studs out, weld up the holes, and re-drill a new pattern using a subaru wheel as a template but the centre would have to be an exact fit to get it right. I'd get an engineering joint to do it.
You might not have to weld up the old holes if you can get the new holes positioned in between the old ones.
vidler
Post by vidler » Wed Jun 18, 2008 7:06 pm
SuBaRiNo wrote:Im trying to work out what rims are on my camper trailer so i can try and locate a set of white offroad style rims for it.
Dave
martin trailer parts sells 4 stud subaru hubs for about $25 a pair i think. bolt straight on, just have to see what size your axle is.
09 Forester XT Touring Wagon
SuBaRiNo
Post by SuBaRiNo » Wed Jun 18, 2008 8:34 pm
Do they sell rims as well V Dawg??
Dave
Post by AndrewT » Wed Jun 18, 2008 8:59 pm
Pretty sure I've been there and seen rims on the shelf before, bit expensive tho.
Although if you're going Subaru hubs you may aswell just get a couple more Speedies :)
SuBaRiNo
Post by SuBaRiNo » Wed Jun 18, 2008 9:35 pm
yeah probably wont go Subaru... there is no added benefit... i Can't fit the same size tyres and rims as my car so it would actually be rather pointless.
Dave
Post by El_Freddo » Thu Jun 19, 2008 11:40 pm
SuBaRiNo wrote:yeah probably wont go Subaru... there is no added benefit... i Can't fit the same size tyres and rims as my car so it would actually be rather pointless.
Seen "the light" dave?
There is a way to get the tyre size that hatchie is using now to fit the camper... I'll leave it to your imagination, you seem to have done well with hatchie so far ;)
SuBaRiNo
Post by SuBaRiNo » Fri Jun 20, 2008 9:56 pm
I physically can fit them on the camper but that will lift the camper higher. Because of the style of it... it will mess things up by making it sit higher. I could always put smaller wheels on the hatch.
Dave
SuBaRiNo
Post by SuBaRiNo » Mon Jun 30, 2008 9:31 pm
Im now after a spare hub for the camper but im not having much luck finding a matching hub. Can someone help diagnose the stud pattern.
It is 4 stud. Each stud is about 7cm apart (middle of stud to middle of stud) And diagonally to each stud is approx 10cm (middle of stud to middle of stud)
Dave
BaronVonChickenPants
Post by BaronVonChickenPants » Mon Jun 30, 2008 9:59 pm
That would be a 4x100PCD, should be fairly common for small cars.
Jordan.
SuBaRiNo
Post by SuBaRiNo » Mon Jun 30, 2008 10:11 pm
Not common enough apparently.
Dave
Post by BaronVonChickenPants » Mon Jun 30, 2008 10:40 pm
4x100PCD: Diahatsu, VW, Nissan Pulsars, Honda Civic, '92 onward Corolla's.
Just be careful, there are some very similar PCD's 4x98 and 4x108, measure to the centre of diagonally opposite bolt holes.
The other thing to watch is the spigot size.
Jordan.
Matatak
Post by Matatak » Mon Jun 30, 2008 10:43 pm
keep going onto That list there BVCP.
4 x 100 is a SERIOUSLY common PCD for the 'smaller' cars.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by BaronVonChickenPants » Mon Jun 30, 2008 11:08 pm
Yeah I figured those examples were enough.
Then again, it's very common if your rim hunting, hub hunting is probably a different matter.
You best bet is to see if the trailer joint jay mentioned can match something up for you.
Jordan.
SuBaRiNo
Post by SuBaRiNo » Mon Jun 30, 2008 11:21 pm
Yeah difficult thing is being able to make it to the joint during the week.
Interesting to see VWs have that size rim... i have seen some nice VW rims about i wouldn't mind. Thanks for the info... should help in my hunt. I will do a more exact re-measure though to make sure it isn't 98mm.
Thanks for the additional info.
Dave
