L series ea82t surging
Mitchhsj
Post by Mitchhsj » Sun May 19, 2013 5:48 pm
my ea82t is doing exactly what yours is by the sound of it. under boost it cleans up a little but still sergers and hesitates but i don't think its pule pressure because when you and flooring it it pulls ok but serges.. I'm thinking the reg too. but before i pulled it out of the other car a month ago the ecs light was on. what is the ECS? because now it off in my l wagon..
ajames
Post by ajames » Sun May 19, 2013 9:03 pm
ECS is the check engine light - look for a red light flashing thru the crack under the steering column then look up the code
Post by steptoe » Sun May 19, 2013 9:39 pm
the wastegate thingy can cause some problems too, have you got a boost gauge onboard ?
Post by Gannon » Mon May 20, 2013 9:26 am
Connect the black test connectors and turn the ignition to 'ON' and the ECS light will flash a code if there is one, or was one that has been saved.
Post by steptoe » Mon May 20, 2013 10:28 am
they might actually be green test connectors on 3 plug ECU
Post by Gannon » Mon May 20, 2013 1:30 pm
From memory for 4 plug ea82 and ej engines. Green plugs connected to read current faults. Black plugs together to read intermittent or stored faults. Both plugs together to clear codes.
Are 3 pluggers different to this?
Post by steptoe » Mon May 20, 2013 6:08 pm
economy model ECU - only green plugs to read codes, fix the fault clears the code I think.Only had to read once, fixed and forgotten
Mitchhsj
Post by Mitchhsj » Mon May 20, 2013 9:03 pm
huh wat? is there a little screen somewhere they displays fault codes? i just striped a entire loon out and put in into my cr and didn't see one. just a red light that flashers in the side of the computer, mine is a 3 plug.. would love to know what your talking about so i can find out whats wrong with it... and no boost controller or gauge yet..
Post by steptoe » Mon May 20, 2013 9:15 pm
that is it Mitch, the little red LED seen inside the ECU.
I'll find some 'structions
ajames
Post by ajames » Mon May 27, 2013 6:55 pm
Well I found the problem that was causing the cold acceleration problems - a vacuum hose wasn't plugged in beneath the intake! So I plugged that back in, started it up, had a few CEL's while it 'learned' what was going on, and now its fine :D
I'm wondering if the cruising surging thing might be the TPS a tad out of alignment??? More testing required...
Mitchhsj
Post by Mitchhsj » Thu May 30, 2013 8:16 pm
very helpful. my computer is flashing so i will try work out what its telling me tomorrow. :)
ajames
Post by ajames » Sat Jun 01, 2013 12:54 pm
well it seems that the problem hasn't completely gone away - when the car's been sitting for a few days its really easy (like 1/2 a second) to start but usually it takes a bit more time and effort when i'm using it more often... i give up!
nncoolg
Post by nncoolg » Sat Jun 01, 2013 2:17 pm
try disconnecting the o2 sensor
# EA82 AWD 4EAT,
Post by El_Freddo » Sun Jun 09, 2013 12:56 am
ajames wrote:I wondered what the chances are that the surging problem could be a bad pump, a dirty/blocked fuel filter, or dirty injectors?
Has anyone suffered the same problems and discovered a solution???
I did an MPFI conversion before I knew better - into a carb'd L series. I too had a surging problem that was similar to what you're experiencing. I put it down to the fuel return line being a small one for the carb and not the larger unit that the standard EFI/MPFI system uses. Replace the fuel return line for the larger unit and I'm sure you'll find the issue settles down.
It's not an easy task but worth the effort IMO.
As Gannon has mentioned, having the injectors etc serviced would be good too.
Post by steptoe » Sun Jun 09, 2013 8:12 am
You are in SA, is that close to Adelaide? coz there is the odd Subaru genius operating repair workshops such as Steve at Rising Sun Service.
How is it going this week ?
ajames
Post by ajames » Thu Jun 13, 2013 3:58 pm
Yeah I'm in Adelaide, I'm becoming more and more tempted to go and see Steve cos he did the conversion in the first place! Apart from dying in a big plume of smoke on the freeway a couple of weeks ago its been ok - there's still an issue which I think is most likely fpr and/or the return line Bennie suggested but I'm going to see if I can find any fuel pump/tank filters to clean out before spending any moula
Mitchhsj
Post by Mitchhsj » Sun Jun 23, 2013 3:38 pm
I'm still having the surging and starting issue bad.. It's giving me a 35 code - egr solinoid and where I'm at now it the solinoid is plugged in but no vacume, bypassed it to the egr valve and now I've disconnected the hose and blocked it off.. I was too wondering if its fuel problem I will get the injectors serviced and I have a bosh o44 fuel pump and 4 m of 3/8 line to bypass the smaller l series line.. But I may have to do the same with the return line. Would this cause the hard starting and surging I'm experiencing ?? I'm at a loss now! :$ thanks guys
Post by steptoe » Mon Jun 24, 2013 8:01 am
test that solenoid that is not connected to any vacuum for the EGR. It may be a case of usual with these old things ... stuck open, stuck shut and registering a code.Test it with 12V fused to see if it operates as in open , close while providing a suction on one end or the other.........total disconnect may or may not work to trick ecu.i
ajames
Post by ajames » Mon Jun 24, 2013 9:12 am
My code 12/33 hasn't come up since I cleaned the connection on the thermoswitch. I ran a can of UEC thru on the weekend and while it was hard to see how much smoke came out, the idle raised itself to 1krpm and it seems to be a tad more driveable but the surging is still there and the coolant needs flushing :( endless things to spend money on!
nncoolg
Post by nncoolg » Tue Jun 25, 2013 8:39 pm
Did you unplug the o2 sensor yet?
# EA82 AWD 4EAT,
