MY thermo wiring trip switch for one fan only
I'd suggest that you look into your cooling system more then. It sounds like there's some other issue at play here, maybe a partially blocked radiator. If you have both thermo fans operating all the time your temp gauge shouldn't move over 1/4 on the gauge. Also make sure your gauge is working correctly.phantomD wrote:Well I respect your opinion, but with the mechanical fan the car temperature used to fluctuate all over the place and it would generally run at 1/4 on the gauge. With both electrics running all the time it is JUST below half way and never moves (unless we have a stinker of a hot day like yesterday!).
Is the top of the radiator hot when at your operating temperature, is the bottom of the radiator cooler on one side more so than the other?
It might be worth pulling the radiator to give it a flush and a shake at the very least, if you really want to check it out take the radiator to your local radiator joint and have them rod the radiator, it should cost about $100. This will clean out the radiator so you know this side of the cooling system is clean.
My 2c anyway, I'd be concerned if both thermos were on and the temp gauge was still on half, even if it is the not so accurate factory dash gauge.
Yeah fair enough.phantomD wrote:Car is fine, only has 55 000km on it and the radiator was rodded recently anyway...nothing. I'm not concerned at all.
So I got the wiring sorted today - did it in an hour but need to tidy it up, I was in a rush (dinner reservation
Best bit is that it also comes on when in the manual ON position
Either way, stoked! Now to teach Gail about how to use this switch - not that she currently gets to drive her Sunnie!
Yeah I was hoping to give it a run today to see if there was a difference running the fan all the time to only having it run when the thermo switch told it too. While it was a warm day there was still too much chill in the air so the radiator did all the cooling at the town speeds that he was getting hot at the other week.nachaluva wrote:great you've got it sorted. Sounds good
Hopefully next week with the hotter weather headed our way I'll be able to tell you more as the wether it did the job or not.
