Fitting ej gearbox to ea engine
H-top
Post by H-top » Tue Sep 01, 2009 10:58 am
My bad :(
I really had no idea they were that uncommon.
H-Top
rolling in
H-top
Post by H-top » Tue Sep 01, 2009 6:24 pm
Well today i got everything rear of the gearbox, now all i need is the box, is there any way i can use a dual range case and internals from a fwd ?
H-Top
rolling in
Post by AlpineRaven » Tue Sep 01, 2009 7:41 pm
H-top wrote:My bad :(
Shit happens mate.. Ive done same thing as well (not gearbox lol)
Post by AlpineRaven » Tue Sep 01, 2009 7:42 pm
H-top wrote:Well today i got everything rear of the gearbox, now all i need is the box, is there any way i can use a dual range case and internals from a fwd ?
Nah wont work. Because the FWD has long main shaft whereabout dual range has 2 piece main shaft.
H-top
Post by H-top » Tue Sep 01, 2009 9:06 pm
Will my rear discs fit onto the rear end of a l series wagon?
As i bought that for my donor parts
H-Top
rolling in
Post by El_Freddo » Tue Sep 01, 2009 9:32 pm
If your vortex is a 2wd the rear discs will not fit without a 4wd rear disc hub. Once you get the 4wd rear end you'll see.
H-top
Post by H-top » Tue Sep 01, 2009 9:55 pm
Is that something i can get from subaru or modify my 2wd ones?
H-Top
rolling in
Post by AlpineRaven » Tue Sep 01, 2009 10:44 pm
H-top wrote:Is that something i can get from subaru or modify my 2wd ones?
If you get it from Subaru.. its... phew... *whistles*
FWD ones wont possible unless you're using FWD only, you need rear discs that will be accept CV joint splines. You cannot modify FWD rear discs as its completely different.
If you are desperate for them, there is a few in NZ. But hard to get in Australia.
H-top
Post by H-top » Wed Sep 02, 2009 6:34 pm
G'day,
I got my rear end today from a 1990 L series Wagon
Including diff, tailshaft and rear KYB suspension (not sure how flogged out yet though)
All this for $100 from the wreckers across the street, hoorah for the boss being connected :)
trying to attach pics :)
Sam
H-Top
rolling in
H-top
Post by H-top » Wed Sep 02, 2009 7:42 pm
Do I only need awd hubs for my discs? Can I use the rest of my fwd rear brakes?
H-Top
rolling in
brumbyrunner
Post by brumbyrunner » Wed Sep 02, 2009 9:56 pm
Settlement Creek Racing
H-top
Post by H-top » Wed Sep 02, 2009 10:04 pm
How did u get them to display like that brumbyrunner?
H-Top
rolling in
phillatdarwin
Post by phillatdarwin » Wed Sep 02, 2009 10:05 pm
u have to used a hos site
Post by El_Freddo » Wed Sep 02, 2009 10:09 pm
^ Nice - that rear end will do the job!
H-top wrote:Do I only need awd hubs for my discs? Can I use the rest of my fwd rear brakes?
You will need the 4wd rear disc brake HUBS to fit your rear discs to the 4wd rear end. I wouldn't want to ask subaru how much a set would cost. They're not necessarily AWD rear hubs, they cam on the RX turbo which is a part time 4wd...
Keep your eyes out for them, they will pop up - that's how I got mine.
brumbyrunner
Post by brumbyrunner » Thu Sep 03, 2009 7:07 am
H-top wrote:How did u get them to display like that brumbyrunner?
phillatdarwin wrote:u have to used a hos site
Nah, they're already hosted, I just changed the code.
I've got some 4WD rear discs here that I'm not using. I would have mentioned them to you before but you seem to be constrained by a tight budget. I also have a constant dual range with 1.59 low range that's collecting dust.
H-top
Post by H-top » Fri Sep 11, 2009 6:39 pm
How much is the price on the 4wd hubs?
H-Top
rolling in
