I really had no idea they were that uncommon.
Fitting ej gearbox to ea engine
Shit happens mate.. Ive done same thing as well (not gearbox lol)H-top wrote:My bad
Nah wont work. Because the FWD has long main shaft whereabout dual range has 2 piece main shaft.H-top wrote:Well today i got everything rear of the gearbox, now all i need is the box, is there any way i can use a dual range case and internals from a fwd ?
If you get it from Subaru.. its... phew... *whistles*H-top wrote:Is that something i can get from subaru or modify my 2wd ones?
FWD ones wont possible unless you're using FWD only, you need rear discs that will be accept CV joint splines. You cannot modify FWD rear discs as its completely different.
If you are desperate for them, there is a few in NZ. But hard to get in Australia.
G'day,
I got my rear end today from a 1990 L series Wagon
Including diff, tailshaft and rear KYB suspension (not sure how flogged out yet though)
All this for $100 from the wreckers across the street, hoorah for the boss being connected
trying to attach pics
Sam
Sam
- 02092009260.jpg (80.87 KiB) Viewed 3381 times
- 02092009259.jpg (82.17 KiB) Viewed 3381 times
- 02092009258.jpg (78.48 KiB) Viewed 3382 times
- 02092009257.jpg (74 KiB) Viewed 3383 times
- brumbyrunner
- phillatdarwin
^ Nice - that rear end will do the job!
Keep your eyes out for them, they will pop up - that's how I got mine.
You will need the 4wd rear disc brake HUBS to fit your rear discs to the 4wd rear end. I wouldn't want to ask subaru how much a set would cost. They're not necessarily AWD rear hubs, they cam on the RX turbo which is a part time 4wd...H-top wrote:Do I only need awd hubs for my discs? Can I use the rest of my fwd rear brakes?
- brumbyrunner
H-top wrote:How did u get them to display like that brumbyrunner?
Nah, they're already hosted, I just changed the code.phillatdarwin wrote:u have to used a hos site
I've got some 4WD rear discs here that I'm not using. I would have mentioned them to you before but you seem to be constrained by a tight budget. I also have a constant dual range with 1.59 low range that's collecting dust.
Settlement Creek Racing
