Drive Brumby in FWD on dirt = write off
Post by El_Freddo » Sun Feb 08, 2009 7:52 pm
the gumbi brumby wrote:will this damage a box takeing off at the lights and abslutely drop it in low range
YES! That's probabily the easiest way to destroy a box, or at the very least your low range...
Also, it low range its best to do a 3 point turn to look after the low range gears, regardless of the surface you're on...
brumbyrunner
Post by brumbyrunner » Sun Feb 08, 2009 9:11 pm
Driveing in a straight line in low range, on a sealed road won't cause the gearbox to bind unless the tyres are different sizes.
But abslutely dropping it any time sure as hell won't do it any favours! :p
Settlement Creek Racing
the gumbi brumby
Post by the gumbi brumby » Mon Feb 09, 2009 6:45 pm
just thort ide ask while we were taking about damaging gearboxs
ive only done it a couple of times and wasent sure (didnt think it was good for it)
but funny takeing of next to a commadore or skylicer
E10 BLEND KILLS CARBY CARS AND RUSTS STEEL TANKS
Phizinza
Post by Phizinza » Tue Feb 10, 2009 9:38 am
If you have larger tyres you can use low range in 2wd (with modded levers) with no problems. The low range gear is very tough, and because where it is in the gearbox you'll more likely break first gear or the 4wd gear using low range where you shouldn't as they will take the brunt of the torque, not the low range gears.
Battlewagon
Post by Battlewagon » Tue Feb 10, 2009 7:14 pm
How do I say this...good clutch control will give you a far better launch than "just dumping it" ever will. Plus it'll be a LOT kinder to your entire driveline.
