Otherwise just take the backing plate off next time you change the diff oil - infact you'd have to do this to find out wether to put LSD oil in or not
Sand work - Pines
jack up the rear end and spin the wheels around, should be able to figure out if its lsd or not.
What should the wheels do exactly?AndrewT wrote:jack up the rear end and spin the wheels around, should be able to figure out if its lsd or not.
I asked about diff oil a week or so ago and some said LSD oil for an LSD and some said the LSD was sealed and the diff proper uses straight differential oil...???aNDREWt wrote:infact you'd have to do this to find out wether to put LSD oil in or not
'00 Forester - H6 - ViPEC V88 - Safari Snorkel
Scorpion Low Range - SubaXtreme Front/Rear Bars - Spring/Strut/Body Lift
nuvi 760 - OziExplorer CE on iPaq212 - Dual Batts - icom ic-400 (comms)
ABS cut out switch - Fan cut out switch
BFG 215/75 ATs
An urge to fly...
BFG 215/75 ATs
An urge to fly...
- vincentvega
Hehehe!!! Well said Dave!D3V1L wrote:yes....limiter.....3 motors and 3 gearboxes later alex....interessting theory
SKT, love the footage of both the sand and the water... Shame the ECU got some of the action too. Glad its up and running again though.
The LSD will make both wheels spin in the same direction when they're jacked up off the ground. A standard diff will make one wheel spin in the opposite direction to the one you're spinning.
LSD's can be a great thing, If its a clutch LSD I know they can be serviced to be tighter, something I hope to do when I get hold of one...
RE: your youtube vid
that's a very ocker Alex 'limiter and shell be right' technique to get out there
Hunter S. Thompson
Hunter S. Thompson
BrennyV wrote:RE: your youtube vid
I was takin water fast...... I couldnt just sit there and wait for the coast guard to rock up
BFG 215/75 ATs
An urge to fly...
BFG 215/75 ATs
An urge to fly...
Lsd diffs came standard on GT and XT foresters (turbo models) not NA models. Spose it could have been a factory option though. Only way to know would be to remove the tail shaft and jack the rear up and turn one wheel and see if the other wheel turns the same way. Im not sure if there is an easier way on these AWDs.
Love the footage and stuff mate... good work.
Dave
Dave
sweet........ i wondered if there was any vid of that......... bring itSubafury wrote:bust some skids, then u'll know. actually come to think of it i have u whipping some tight nuts at 90 acres. def LSD. ill upload for ya. should sort the question
BFG 215/75 ATs
An urge to fly...
BFG 215/75 ATs
An urge to fly...
http://s194.photobucket.com/albums/z285 ... squirt.flv
I have that dunno if it ever went up before. tis not much really.
matts is prolly better
Wagon is no longer....
Man...... when was that...??? July....???Matatak wrote:http://s194.photobucket.com/albums/z285 ... squirt.flv
I am still washin that shit out hey?!?!?!
When i drove away i hit that deep hole and temporarily misplaced my number plate.... hehehe
BFG 215/75 ATs
An urge to fly...
BFG 215/75 ATs
An urge to fly...
- RetroLover
Gun it untill it becomes free. BTW love the reply comment to lukeevans1978, pure classic, lol.SKT wrote:Went swimming..... found a deep hole in the middle of a crossing just big enough to swallow the left side.... took on a lot of water and soaked the ECU.... $1500 later.... ECU+Imob+Key package and a wheel bearing and he's good as new. Maybe even better
I'd like some opinions on whether I've got and LSD in the rear because Al told me I did now.... I thought it would do better putting a heap of drive to the left wheel once that right wheel started spinnin like a mofo...
http://au.youtube.com/watch?v=OhYwV-7hAaE
First one wont work for me dude.....
Cheers for the second though... I feel guilty for the abuse now.... kinda
BFG 215/75 ATs
An urge to fly...
BFG 215/75 ATs
An urge to fly...
both those vids are the same one
Nothin fancy bro....... I just rocked up to a random exhaust shop when i was in townsville and asked for a 2.5" from the cat back with a steel main straight for bashin and a nice suby note....El_Freddo wrote:SKT, I love that exhaust note, could you post some details of your exhaust setup?
They went to work and about $300 later it sounded ok....
After i put the 2.5L in it was actually a bit loud and a bit too resonant so i had a second box put in towards the back...... Settled it down a bit and better on teh open road.
BFG 215/75 ATs
An urge to fly...
BFG 215/75 ATs
An urge to fly...
