Sand work - Pines
Post by AndrewT » Mon Oct 27, 2008 11:28 pm
jack up the rear end and spin the wheels around, should be able to figure out if its lsd or not.
Otherwise just take the backing plate off next time you change the diff oil - infact you'd have to do this to find out wether to put LSD oil in or not :)
SKT
Post by SKT » Mon Oct 27, 2008 11:35 pm
AndrewT wrote:jack up the rear end and spin the wheels around, should be able to figure out if its lsd or not.
What should the wheels do exactly?
aNDREWt wrote:infact you'd have to do this to find out wether to put LSD oil in or not :)
I asked about diff oil a week or so ago and some said LSD oil for an LSD and some said the LSD was sealed and the diff proper uses straight differential oil...???
'00 Forester - H6 - ViPEC V88 - Safari Snorkel
Scorpion Low Range - SubaXtreme Front/Rear Bars - Spring/Strut/Body Lift
nuvi 760 - OziExplorer CE on iPaq212 - Dual Batts - icom ic-400 (comms)
ABS cut out switch - Fan cut out switch
BFG 215/75 ATs
An urge to fly...
vincentvega
Post by vincentvega » Tue Oct 28, 2008 8:49 am
if its a viscous LSD (which it most likely will be) then you don't need special gear oil
look at teh sticker on the rear of the diff. it will tell you if its an LSD
Post by El_Freddo » Tue Oct 28, 2008 3:24 pm
D3V1L wrote:yes....limiter.....3 motors and 3 gearboxes later alex....interessting theory :)
Hehehe!!! Well said Dave!
SKT, love the footage of both the sand and the water... Shame the ECU got some of the action too. Glad its up and running again though.
The LSD will make both wheels spin in the same direction when they're jacked up off the ground. A standard diff will make one wheel spin in the opposite direction to the one you're spinning.
LSD's can be a great thing, If its a clutch LSD I know they can be serviced to be tighter, something I hope to do when I get hold of one...
BrennyV
Post by BrennyV » Tue Oct 28, 2008 4:06 pm
RE: your youtube vid
that's a very ocker Alex 'limiter and shell be right' technique to get out there ;)
Hunter S. Thompson
SKT
Post by SKT » Tue Oct 28, 2008 5:38 pm
BrennyV wrote:RE: your youtube vid
I was takin water fast...... I couldnt just sit there and wait for the coast guard to rock up ;)
BFG 215/75 ATs
An urge to fly...
SuBaRiNo
Post by SuBaRiNo » Tue Oct 28, 2008 7:46 pm
Lsd diffs came standard on GT and XT foresters (turbo models) not NA models. Spose it could have been a factory option though. Only way to know would be to remove the tail shaft and jack the rear up and turn one wheel and see if the other wheel turns the same way. Im not sure if there is an easier way on these AWDs.
Love the footage and stuff mate... good work.
Dave
Post by Subafury » Tue Oct 28, 2008 9:43 pm
bust some skids, then u'll know. actually come to think of it i have u whipping some tight nuts at 90 acres. def LSD. ill upload for ya. should sort the question
SKT
Post by SKT » Tue Oct 28, 2008 9:47 pm
Subafury wrote:bust some skids, then u'll know. actually come to think of it i have u whipping some tight nuts at 90 acres. def LSD. ill upload for ya. should sort the question
sweet........ i wondered if there was any vid of that......... bring it
BFG 215/75 ATs
An urge to fly...
Matatak
Post by Matatak » Tue Oct 28, 2008 10:07 pm
http://s194.photobucket.com/albums/z285 ... squirt.flv
I have that dunno if it ever went up before. tis not much really.
matts is prolly better :p
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
SKT
Post by SKT » Tue Oct 28, 2008 10:13 pm
Matatak wrote:http://s194.photobucket.com/albums/z285 ... squirt.flv
Man...... when was that...??? July....???
I am still washin that shit out hey?!?!?!
When i drove away i hit that deep hole and temporarily misplaced my number plate.... hehehe
BFG 215/75 ATs
An urge to fly...
Matatak
Post by Matatak » Tue Oct 28, 2008 10:24 pm
What that stuff :p
according to my photos it was the 8th of June
twas a good trip ;)
Post by Subafury » Tue Oct 28, 2008 10:28 pm
there ya go, definetely has LSD.
http://au.youtube.com/watch?v=ZKD9Fsx-yqA
RetroLover
Post by RetroLover » Wed Oct 29, 2008 12:22 am
SKT wrote:Went swimming..... found a deep hole in the middle of a crossing just big enough to swallow the left side.... took on a lot of water and soaked the ECU.... $1500 later.... ECU+Imob+Key package and a wheel bearing and he's good as new. Maybe even better :cool:
I'd like some opinions on whether I've got and LSD in the rear because Al told me I did now.... I thought it would do better putting a heap of drive to the left wheel once that right wheel started spinnin like a mofo...
http://au.youtube.com/watch?v=OhYwV-7hAaE
Gun it untill it becomes free. BTW love the reply comment to lukeevans1978, pure classic, lol.
SKT
Post by SKT » Wed Oct 29, 2008 7:50 am
Subafury wrote:there ya go, definetely has LSD.
First one wont work for me dude.....
Cheers for the second though... I feel guilty for the abuse now.... kinda :rolleyes:
BFG 215/75 ATs
An urge to fly...
Post by AndrewT » Wed Oct 29, 2008 9:37 am
both those vids are the same one :)
Post by Subafury » Wed Oct 29, 2008 12:20 pm
yeh posted it twice because it doesnt work for all people if you click the 'insert picture' button and then paster the link- matatak was having trouble but i wasnt. just pasting the url and nothing else. that seems to work for everyone
Post by El_Freddo » Wed Oct 29, 2008 12:26 pm
SKT, I love that exhaust note, could you post some details of your exhaust setup?
SKT
Post by SKT » Wed Oct 29, 2008 5:39 pm
El_Freddo wrote:SKT, I love that exhaust note, could you post some details of your exhaust setup?
Nothin fancy bro....... I just rocked up to a random exhaust shop when i was in townsville and asked for a 2.5" from the cat back with a steel main straight for bashin and a nice suby note....
They went to work and about $300 later it sounded ok....
After i put the 2.5L in it was actually a bit loud and a bit too resonant so i had a second box put in towards the back...... Settled it down a bit and better on teh open road.
BFG 215/75 ATs
An urge to fly...
Matatak
Post by Matatak » Wed Oct 29, 2008 5:45 pm
so when you heading out next SKT ??
Return to “Western Australia”
