liberty box centre diff
heath
Post by heath » Sun Jul 20, 2008 11:31 am
has anyone welded the centre diff on a liberty box to make it a true 4wd
steve_rising_sun
Post by steve_rising_sun » Sun Jul 20, 2008 11:39 am
How are you going to drive it on the road? welding it is easy.
Steve
heath
Post by heath » Sun Jul 20, 2008 11:41 am
just talking the centre diff you would still be able to drive it on the road
vincentvega
Post by vincentvega » Sun Jul 20, 2008 1:31 pm
no mate. you need a center diff to be able to drive on road. go do some reading...
brumbyrunner
Post by brumbyrunner » Sun Jul 20, 2008 9:19 pm
There was an MY sedan advertised on here for sale a few years ago that had one. Was used for rallying, had a full cage and CAMS approval. Also had an EJ22/constant 5 speed conversion.
Settlement Creek Racing
heath
Post by heath » Mon Jul 21, 2008 8:33 am
thanks i no of people that have welded there rear diff( a cig locker) but they did ahve truoble turning at low speeds on the road. but was thinkin that the front and back diffs would still work so you could drive it on the road. it was just an idea didn no if it was possible. will just go the ea82 dual range box instead
discopotato03
Post by discopotato03 » Mon Jul 21, 2008 10:11 am
The rally spec viscous centers would be a better bet but still a bit baulky on the blacktop , talk to Gareth - bratgeebra - ran one in his brumby .
There is one smart fella that worked out how to do a mechanical diff lock in the EJ type (longbox) but not sure how .
A .
BrennyV
Post by BrennyV » Mon Jul 21, 2008 11:58 am
my liberty wagons center is locked. Tho im not running a rear lsd yet, so its still fairly drivable with 27's. ill let you know what its like once the lsd goes in the rear ;)
Hunter S. Thompson
heath
Post by heath » Mon Jul 21, 2008 12:33 pm
i thought it would be possible how did you lock the centre. and will be very interested to see how it goes with the rear lsd
Post by El_Freddo » Mon Jul 21, 2008 12:37 pm
Heath, I'm guessing that your looking at modding a liberty for offroading.
If you really want a lockable centre diff in the lib the EA Fulltime 4wd gearbox is the way to do it - it will fit in the liberty's gearbox casing without any trouble.
Problem is the availability of these L AWD lockable centre diff gearboxes. An alternative is to get a Dual Range Part Time L series boxes and fitting that into the liberty casing, taking with it the better low range gearing. A little more trouble to do as the low range selection fork needs welding to allow the ball and spring to hold it in place - its different to the L PT box.
Or do as most members do with liberty boxes, just change the low range gearing and leave it at that - apparently there's not a lot of difference in the box's performance between the lib and L/MY 4wd boxes.
Hope this helps.
heath
Post by heath » Mon Jul 21, 2008 12:43 pm
thanks bennie. the reason i asked is because i just picked up a ej20 with the box attached really cheap so just explorin my options. i would rather the constant ea box but it comes down to price and findin one
