I got 'harmonic balancer' on my EA82T
Post by steptoe » Mon Jul 14, 2008 8:31 pm
cannot find the discussion where some have claimed subies don't need or have harmonic balancers, just belt pulleys and others have said they have got or seen them - rubber sandwiched in the pulley.
looking at my Ea82T's and both have rubber - sort of remember now when drilling through to fit roll pins , i drilled through some rubber
and here should be a photo ( thanks to imageshack.us/ )
Post by Gannon » Mon Jul 14, 2008 8:49 pm
Got pics?
I believe that they probably did come with them, but they weren't entirely necessary. More of just a precaution
discopotato03
Post by discopotato03 » Tue Jul 15, 2008 10:20 am
IMO most EA81/82 engines don't rev very high or for very long - they don't breathe very well so there's not much torque up in the rev range (in a lot of ways I cannot understand why Subaru even bothered with the carburetted single inlet port EA82 because minor revisions of the EA81 could achieve the same thing with less weight/bulk/cost) .
Exceptions would be the turbocharged MPFI EA82 - and these don't make power very high up the rev range in std form anyway . I think the fact that the early RX's were partially homologation models for production rally car classes may have had an influence as well .
One other that would be interesting to check on would be the twin carb all revs 1400 engine . Someone I know had a friend that bough one of those things new and reckoned it reved like a turbine so there's a fair chance they made have had a harmonic balancer as well .
Just for the record such a pulley is probably of zip benefit unless you intend to run your (std EA81/2 NA) engine at 6000+ revs on a regular basis or for any length of time .
For anything less it's just a bit more innertia for the engine to have to accelerate/decelerate .
A .
