1985 subaru
bundydave
1985 subaru
Post by bundydave » Mon Jun 16, 2008 6:52 pm
hi i got a 1985 subaru sedan and got an ea98 engine and i cant undo the harminic ballencer how
suby87
Post by suby87 » Mon Jun 16, 2008 7:19 pm
Hey mate
If you have a 85 Leone it will have the EA82 engine not EA89. It does not have a harmonic balancer it has a simple crank pulley, the way to undo it is on top of the bell housing is a black rubber cover pull it out and you will see the fly wheel. Turn the fly wheel till you see one of the many holes in it jam something in that hole eg screwdriver then turn the bolt on the front of the crank pulley the usual direction with someone holding the pin in the fly wheel. Its a bit hard the first time but once you have done it a couple of times it becomes real easy. It took me over a hour the first time to figure it out and a lot of skinned knuckles (bloody radiator).
Cheers Kris
littlewhiteute
Post by littlewhiteute » Mon Jun 16, 2008 8:25 pm
I've done it that way at the wreckers, but the easy way is to put on a socket and long breaker bar, allow the bar to strike the ground or chassis rail as you hit the starter, disable the ignition so the motor doesn't start, works every time and no skin off. ;)
Gary ;)
Post by El_Freddo » Mon Jun 16, 2008 9:12 pm
Or select 4th/5th, put the handbrake on and use a long breaker bar. Take the "slack" out of the system then go for it. Works everytime for me ;)
bundydave
Post by bundydave » Thu Jun 19, 2008 4:56 pm
thanks alot found the problem it was a broken timing belt now need help where r the timing marks
Post by steptoe » Thu Jun 19, 2008 11:02 pm
three lines on the flywheel or drive plate on auto NOT the timing marks. You will need to find the electronic manual in here if you not have one. too hard for me to relay at the moment
Post by El_Freddo » Thu Jun 19, 2008 11:28 pm
steptoe wrote:You will need to find the electronic manual in here if you not have one. too hard for me to relay at the moment
Scroll down in here to BYB's post - this is the electronic manual, the best info you'll find on the EA82 in one place.
