Ground for amps
ol kid
Ground for amps
Post by ol kid » Tue May 06, 2008 2:57 pm
Hey again, Ive never worked on a Gen 1 lib but im not sure as to were to the Earth for the amp. Ive got it hooked up to the nuts that hold in the Tail light in. The sub make some alien Popping noises and then when the cd picks up it goes away? Im not sure as to what this is... Cheers Ethan
Current Ride - 85 Touring wagon, All electrics, KYB long travel struts, Power Steer, Mags (swapping for sunnies). :mrgreen:
tex
Post by tex » Sun May 25, 2008 3:13 am
try running a decent wire to the battery the bigger the wire the better the sound and the louder it goes the same goes for the power wire but put In a fuse. As it is the more you turn it up the more it crackles.
vincentvega
Post by vincentvega » Sun May 25, 2008 10:08 am
any solid bolt on the body will do as long as your earths in the engine bay are good.
make sure you grind all the paint off where you are bolting the eye to the body. Paint is not a conductor...
