EJ22 motor wanted in Melbourne
PeterVWsuby
Post by PeterVWsuby » Sun May 04, 2008 10:24 pm
I have a 1975 Volkswagen bus powered by EJ22 for many years, and finally this motor has problems. The conrod bearings have gone. I have had quotes for second hand motors for $660 from wreckers for EJ22, and $880 for EJ22 with new rocker gaskets and cam belt with 3 month warranty.
I thought I would try here and see if anyone has a running Subaru they are planning a late model or turbo conversion, and the original EJ22 will not be required, and I can give cash to a person rather than a business if possible.
I already have everything, just mainly the long engine is required, I already have the computer, igniter, fuel pump, exhaust etc. This is just a replacement for an already running, but sick motor. It sounds like a monkey is inside with a shifting spanner, trying to get out.
seagull
Post by seagull » Sun May 04, 2008 10:44 pm
$800.00 looks to be the going rate Peter
I have one in Perth , low ks $800.00 ( shipping + $140.00 )
New timing belt & bearings $240.00
remove & clean injectors $140.00
New water pump $145.00
New manifold gaskets $30.00
runs mint
Post by El_Freddo » Sun May 04, 2008 10:48 pm
Where are you Peter?
A pick a part joint could be the go, $220 for a complete engine (or there abouts, prices just changed and haven't seen them yet). You could drop that in while you rebuild the monkey one. Problem is that you don't know the condition when you get it unless the car has been written off - which is usually a good indication that the motor was running well...
PS welcome to the forum!
PeterVWsuby
Post by PeterVWsuby » Mon May 05, 2008 9:33 pm
Tried the local Pic -apart. They only had L series, no EJ engines. The Suby and Jap wreckers were the ones I rang to get the above prices, and they all seemed pretty much on par with each other. I just think that if I can save a few bucks, and someone else can get a few, and we are both happy, then it may work out a good swap.
Post by AlpineRaven » Mon May 05, 2008 10:07 pm
If you are in Victoria, Im sure Pick-A-Part and Jollys would have EJ22s for somewhat $180-$220?
PeterVWsuby
Post by PeterVWsuby » Sat May 24, 2008 2:03 pm
Still looking for EJ22. No hurry, just letting anyone who has one they may need to offload.
Post by El_Freddo » Sun May 25, 2008 8:44 pm
PeterVWsuby wrote:Still looking for EJ22. No hurry, just letting anyone who has one they may need to offload.
There was a good one down at centre road wreckers - I can't remember what its called now, as its changed hands.
There was a rolled liberty with 21xxxx km on the clock, the best pick of the bunch as far as I'm concerned. If I had the money i would be in my shed waiting to be dropped into the mighty (yet in need of some TLC) L series...
Happy hunting.
PeterVWsuby
Post by PeterVWsuby » Tue Jun 03, 2008 7:59 pm
Still looking. Not all wreckers have one at the moment, and those that do have either unusual conditions, or the price is hundreds more than I would expect.
I can wait.
seagull
Post by seagull » Tue Jun 03, 2008 8:05 pm
I sold mine today for $850.00 200000ks & my mates went for $1400.00
( done 50,000ks ) on sunday , so there still pulling good $
PeterVWsuby
Post by PeterVWsuby » Wed Jun 25, 2008 6:18 pm
Just bumping post to see if any motors have turned up?
Post by AndrewT » Wed Jun 25, 2008 6:31 pm
$800 is NOT the going rate for an EJ22 motor by itself. If you pay that you are being ripped off. You should be able to get one for around $500 and that would most likely be including the wiring loom and ECU. It's worth paying a little more for one with less than say 150,000kms on it.
Look around and you should find one for a reasonable price. Try checking out your local damaged cars auctions.
fyi just today Matt just bought an entire EJ22 liberty with extremely minor front end damage (not even ruptured radiator) for $800 flat - only 180,000kms and in very very good condition.
SubaRute
Post by SubaRute » Wed Jun 25, 2008 9:18 pm
lol i have one here in qld but freight might be your downfall? asking price is $500.00 180+km not much else i can tell you but it was going good,and has been sitting in the shed for the last 8months.PM,text,phone,0417623931 or email [email protected] cheers and good luck hunting, leon aka subarute
PeterVWsuby
Post by PeterVWsuby » Sun Jun 29, 2008 10:42 pm
$500 for a basic engine would be a good price. I am ready to pay if someone has one
PeterVWsuby
Post by PeterVWsuby » Thu Jul 24, 2008 9:04 pm
Got one for $800. Put it in and it is all good.
Return to “Wanted”
