The ute is required to pull about a 750kg GTM 8x5 up the Adelaide South Eastern freeway at 100. (steep ass freeway for those who do not know it) My '04 XS Forester Auto will not do this without hunting so that is the benckmark I want to reach. Mainly because the XS is damn close to hunting on the flat at 100.
Oh yeah, looking to sell the XS once I get the ute sorted.
Not at all concerned about off road ability. I like to have a play in the sand but that is secondary to the trailer and reliability. I am happy to lift it if required to get the engine in, and it can be done legit.
Anyway, I am after opinions on the best course of action. I am undecided on either the EA82T , EJ20T or even possibly the EJ22 route.
Same same on gearboxes, I understand the gearboxes a very similar to LEGO ie mix n match. But I do not know the what variants are out there. At this point I expect to stick with whatever comes with the engine but that is open for discussion.
I plan on getting the engine in a half cut for the ECU, loom and emission gear, see below.
I also believe the disk rear off a 4wd L can be swapped bolt for bolt with the MY rear drums? Are there any other disks that will fit as a bolt in replacement ?
I used to have a 92 Brumby running an EA82T, straight LPG and with the air to water intercooler ran 20 PSI. HP wise it would have been more than ample for what I am trying to do now it that helps the decision process. It also BADLY needed an AWD box, I was once a bit energetic on a damp evening and managed to torque steer a lane change at 90kph. Scary but Wow! 8O .Awesome grin factor but I am not going to be happy with straight gas on this one. Too many country k's to not be able to run unleaded.
Number one priority, it must be street legal. I am happy to do the leg work with engineers if anybody knows a subie friendly engineer in Adelaide ?
After that, reliability as I do a lot of long distance towing
Fuel economy, the ute is dual fuel currently and I would like to continue that. Yeah I know, HP = Fuel burn
Anyway, open to opinions and ideas.
Pete
