Which got me thinking.....
Why not mount a temp sensor or switch on the cylinder head (which is where the most damage occurs in an overheat, ie. headgasket or exhaust port/water-jacket crack) to warn when the cylinder head reaches a dangerous temperature?
After a bit of research, i found that some cars utilise CHTS (mostly air cooled engines like Porsche and VW)
I can see two ways of doing it...
1. Mount the factory temp sender to the head (as opposed to the thermostat) and connect it to the factory temp gauge on the dash
2. Use a thermocouple and a digital display to have an accurate display of CHT, here is an example of a thermocouple that installs between spark plug and head
Opinions anyone?
