New Project begins
maxxair
Post by maxxair » Thu Apr 03, 2008 1:19 am
fair enough, how difficult was that? say i want to convert single to duals??
Cheers, Rohan M.
85wrx
Post by 85wrx » Thu Apr 03, 2008 7:42 am
The way I converted it was to swap the entire radiator support panel. There is a fair amount of drilling out spot welds and welding of the new one in.
Thalass
Post by Thalass » Thu Apr 03, 2008 10:16 pm
Wow, this is very nice. So that's a rex dash you've put in? Interesting... I wonder if an outback dash will fit in a brumby.... :P
85wrx
Post by 85wrx » Fri Apr 04, 2008 8:41 am
It is not as easy as just fitting. There is alot of cutting to get to this point as well as many test fits. The dash is still along way off being finished. The ends and the top corners need to be fabricated, filled and the dash covered. Also the whole heater assembly ducting to be made and windscreen demister cover fitted.
Thalass
Post by Thalass » Fri Apr 04, 2008 2:14 pm
Ah but it's possible and that's the interesting bit. I've become much too attached to my outback's aircon system and dash layout, you see. :p
heath
Post by heath » Sun Apr 13, 2008 8:23 pm
So does anyone sell a kit to install a ej2.2 into an my or do u have to build it yourself. Iv seen the kits to adapt the ea81 and 82 boxes to them but thats all
Post by El_Freddo » Mon Apr 14, 2008 11:50 am
heath wrote:So does anyone sell a kit to install a ej2.2 into an my or do u have to build it yourself. Iv seen the kits to adapt the ea81 and 82 boxes to them but thats all
Try contacting BYB-01 (Brett) or Subi Wan Kanobi - also check out the thread in the "Conversions, Modifications and Performance" section about the EJ engine into EA vehicle, there should be info there about adaptor plates.
Also do a search on this site, it may come up with what your after.
tex
Post by tex » Sun May 11, 2008 6:53 am
Thalass wrote:Ah but it's possible and that's the interesting bit. I've become much too attached to my outback's aircon system and dash layout, you see. :p
Yes but anything is possible provided there was enough money, time and frustration involved and from what I see theres a lot of each in this namely the last two am I right, I looked into putting a Lib dash into my brumby and decided that I had other things to do on it first!
85wrx
Post by 85wrx » Sun Jul 13, 2008 5:27 pm
It has been a while since I updated what has been going on.
1. Purchased and fitted front coilovers. (see pictures still a tad too low)
2. Starting to fill in the corners of the dash pad and today started to fix up the ends. (getting it all ready to be recovered). Only othert outstanding part of the dash is to route and manufacture air ducting for demister and the likes.
3. Front spoiler is getting there. Need to work out how to attach it.
4. Rear end including brakes fitted up. Just requiring the park cables to fitted and connected.
There is still alot to do but it is getting there. Next will be to remove the engine to get it ready for painting. I will need to warm up a bit as it is going to be sprayed in 2 PAK.
Enjoy
vincentvega
Post by vincentvega » Sun Jul 13, 2008 5:52 pm
i love everything you have dont to this thing except that spoiler! yuk!
awesome work mate.
Post by El_Freddo » Sun Jul 13, 2008 8:45 pm
vincentvega wrote:i love everything you have dont to this thing except that spoiler! yuk!
awesome work mate.
Agreed - but its not our car now is it?
It'll be a sweet unit once its all together. I also admire the amount of work that's gone into mounting the WRX dashboard in the coupe. Top effort!
aussie_guy00000
Post by aussie_guy00000 » Sat Jul 26, 2008 5:51 pm
Hey mate, looks great so far. I'm doing pretty much the exact same thing with a brumby, dash and all over here. I was just wondering how you went fitting the WRX (if that's what you've used) heater box, fan and A/C evap in behind the wrx dash. Also how did you mate the fan to the opening in the firewall (for fresh air)? Did you have to modify the fire wall much? I don't suppose you could share a pic of the set up with the dash removed so I can see how it all fits in there? Are you using the WRX steering column? did you have to weld up new mounts for it? Sorry for the barrage of questions, just keen for a bit of a leg up :D Cheers and good luck with the rest of the build.
85wrx
Post by 85wrx » Sun Sep 21, 2008 7:05 pm
Here is the latest pictures of the completed dash pad recovered and temp fitted. Not much has changed. Just completing alot of the little things that will tie the whole project together when it is done.
Engine is removed ready to tidy up then paint. Aiming to have the engine bay painted, engine and gearbox fitted with all the wiring sorted by then begining of next year. That gives me all next year to complete the body and have it on the road by dec 2009.
Enjoy
dash 4.JPG (97.45 KiB) Viewed 6864 times
dash 3.JPG (90.74 KiB) Viewed 6886 times
85wrx
Post by 85wrx » Sun Nov 02, 2008 6:15 pm
Started the painting of the engine bay and assembly of some of the components. Today I fibreglassed a copy of a series 1 scoop to the bonnet. All the scoop ducting matches up perfect and will be removable. This is thanks to stainless ducting from zerosports. This will be it for a month off to work up north. Still aiming to get the engine in for good by christmas. This depends on the amount of work with the loom.
chubby37
Post by chubby37 » Tue Dec 23, 2008 1:45 pm
any more news on this car at all????
Post by AlpineRaven » Tue Dec 23, 2008 4:19 pm
she'll be very different.... keep it up...
85wrx
Post by 85wrx » Wed Dec 24, 2008 6:04 pm
I have completed alot in the last 2 weeks. The engine and gearbox is in, the wiring is 98% complete on the car, the engine bay is 95% complete and i have started the car and had it running. It is a tad noisy with just dump pipe and cat finishing at the back of the gearbox.
The climate control and dash is in, wiring is completed under the dash. All the switches and items work.
Today I started on finishing the front spoiler and started on the body work and prep ready to start and paint. I am aiming to have it finshed in another 6-8 months.
I will post some pics over the weekend showing where it is up too.
85wrx
Post by 85wrx » Fri Dec 26, 2008 6:36 pm
As promised. Here are the latest pictures of the car as it stands.
front new.JPG (88.03 KiB) Viewed 6775 times
engine new.jpg (75.9 KiB) Viewed 6774 times
dash new.jpg (63.25 KiB) Viewed 6773 times
chubby37
Post by chubby37 » Fri Dec 26, 2008 7:12 pm
nice...looks like its all ment to be there and thats the secret to a great conversion.....top effort
lovey80
Post by lovey80 » Fri Dec 26, 2008 11:47 pm
Really good effort there mate? How long do you thin until it is finished. That dash looks really good was there a big problem getting it to fit? How long was the install?
Chris
